Parts Fan switch - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 12-03-2008, 08:59 PM Thread Starter
Amoosbenz's Avatar
Date registered: Jun 2008
Vehicle: 1971 250 1988 420SEL
Post Parts Fan switch
Looking for a fan switch for a 71 250 also maybe the blower motor.... Any recomended parts suppliers?
Thanks
Amoosbenz is offline
post #2 of 6 (permalink) Old 12-04-2008, 02:58 AM
Eirik 400 SE's Avatar
Date registered: Jan 2008
Vehicle: 1973 W115 200 /8
Wich 250 ?
A W108 or W114 ?
If you mean W114, I would test the fan by hooking up some cables directly to the coupling on the front wall.. There are 1ground, and 3 different speed connectors.
Don't remember wich is wich.. But in many cases it's the resistance-block inside the ventilation chamber (in front of the windshield) that has stopped working.
1991 W140 400 SE - SOLD !!
1973 W115 200 -For sale as project.
Eirik 400 SE is offline
post #3 of 6 (permalink) Old 12-04-2008, 05:26 PM Thread Starter
Amoosbenz's Avatar
Its a W114 any pictures or diagrams on how to get to it? I was going to wire my own swith but thats just stupid:-) I am assumeing I have to get to it from the top of the dashboard?
Benny
post #4 of 6 (permalink) Old 12-05-2008, 03:31 AM
Hi.
Do you have a standard heater or a BEHR AC ?
If you have the standard heater.. Then it will look like this:
Ê*ò*ëîã
At the top picture you see part no 64.. Wich is the fan-regulator. That one is placed here:
Just inside the ventilationchamber in front of the windshield. It's held in place with 2 philips-screws..
As you can see here, at my ongoing restaration, the plug is right above the brake-booster.
Here you can hook up the wires to the 4 pins inside the plug, and in that way dry-run the fan itself.. If the fans spins up, at all three speeds, then the resistance-box is ok, and the problem is likely to be in the main switch in the dashboard (or the fuse ??)
Or, of course, the fan itself..
You only have to dismantle the wiper-blades AND the vetilation-grill to remover the resistance-box..
To get to the FAN, you have to onhook the water-hoses, and then romve the complete vetilation-system from within the car.. A rather big job actually.. But not that many bolts & Screws..
post #5 of 6 (permalink) Old 12-05-2008, 10:31 AM Thread Starter
Amoosbenz's Avatar
I have the A/C I tested the blower and thats good so its going to be the box..... I am having alot of fun restoring this car:-)
post #6 of 6 (permalink) Old 12-10-2008, 12:31 AM
Date registered: Dec 2008
Would you please explore your question some more
trinitybrown is offline
Aux Fan Switch?? BoRegards W124 E,CE,D,TD Class 1 08-16-2007 07:34 AM
Fan speed switch? techfury90 W201 190-Class 0 03-18-2007 07:17 AM
aux fan switch? P4olom W123 E,CE,D,CD,TD,TE Class 2 03-12-2007 08:00 PM
Fan Switch for A/C BILLYFEET W201 190-Class 2 09-15-2004 05:39 PM
Fan Switch on 113 pcm0928 V-Class 2 05-26-2004 12:42 PM
