1975 300D Glow plug - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 11-22-2008, 12:05 PM Thread Starter
Date registered: Mar 2007
Vehicle: 1976 300D, 2002 E320 Wagon
1975 300D Glow plug
The glow plug indicator on the dash does not light up. The battery checks out fine and the ground connection is good. All of the fuses look good and the connections on the glow plugs are tight. Is there a way to isolate a bad glow plug or do I have to remove all of them for testing?
ehytrek is offline
post #2 of 2 (permalink) Old 11-23-2008, 09:47 PM
Date registered: Jun 2008
The glow plugs in those years are wired in series. 1 bad plug will cause the whole system to not work. You could use a volt meter and make sure the resistance between where the power goes to the first glow plug and the ground strap is low. It should not be more that a few ohms. Pull the plugs and check the resistance out individually if total resistance was high.
bagawk is offline
    Glow plug indicator (and more) -- 1987 300D KrisH General Mercedes-Benz 5 02-23-2011 09:34 AM
    85 300d glow plug please help roempty General Mercedes-Benz 1 11-23-2004 10:29 AM
    Glow Plug/Light Question '81 300D Joey W123 E,CE,D,CD,TD,TE Class 2 10-09-2004 01:32 PM
    Any One Have A Glow Plug Relay For Sale?? 83 300d panamacolin W123 E,CE,D,CD,TD,TE Class 0 08-23-2004 09:00 PM
    300D glow plug indicator freaking out Guest (MBNZ) W124 E,CE,D,TD Class 1 11-13-2001 11:28 AM
