First gear whine - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 11-11-2008, 04:01 AM Thread Starter
Date registered: Aug 2006
First gear whine
Hi folks,
Is there any way to get the first gear in my 4 speed manual transmission to be quieter - it sounds like a straight cut gear
This is from a W126 with an M110. I changed the oil (ATF+additive) to no avail
I thought of using regular transmission oil but MBZ does not recommend it - there must be a reason right ?
Any help would be appreciated.
Denis
Lion sur Mer
France
Dlespera is offline
post #2 of 5 (permalink) Old 11-25-2008, 09:45 AM
diametricalbenz's Avatar
Date registered: Oct 2005
Vehicle: '77 6.9, 74 240D, 96 Ram 5.9L Cummins, 02 Civic EX, 10 Mazda 5 Sport
Quoted: 4 Post(s)
Did you just buy the car or did the sound appear all of the sudden?
1977 - W116 - 6.9
1974 - W115 - 240D /8 - 4(M) OM617.910 + Turbo + 300D FW - Completed 7/8/10
diametricalbenz is offline
post #3 of 5 (permalink) Old 11-27-2008, 02:21 AM Thread Starter
First gear whine
Hi
It's been like that ever since I bought it a year ago. I did a fluid change to the proper ATF and it has improved a bit. Both the diff and the manual gearbox emit acceptable noise levels on the highway in 2nd ,3rd and 4th gear but first is a "whiner" that sounds a bit like straight cut gear (even though it is not a straight cut gear).
I thought of mixing the ATF with high grade 75-90 gearbox oil. Any thoughts on doing this ?
Denis
Lion sur Mer
France
Dlespera is offline
post #4 of 5 (permalink) Old 11-27-2008, 02:31 AM
Date registered: Jun 2004
Quoted: 17 Post(s)
You have a worn bearing in the "cluster" gears. A 50/50 mix of 90 and ATF will not cure the noise but will cut it down a bit and allow the transmission to last a little longer. It's on it's way out I'm afraid and has probably been damaged by abuse by a previous owner. They normally silent in any gear. Thats an unusual combination though,I have owned w114's and And W123's with the m110 and manual transmission but i have never thought any one would order a W126 with manual.
mercmad6.3 is offline
post #5 of 5 (permalink) Old 11-27-2008, 03:00 AM Thread Starter
W126 with manual
Hi
A W126 with a manual gearbox and M110 engine is a very common configuration outside America. I only wish it were a 5 speed.
In France, people simply don't like automatic transmissions...probably because they were power eaters and increase fuel consumption many years ago. Their reputation is quite tarnished
Thanks for he insight !
Denis
Lion sur Mer
France
Dlespera is offline
    Whine...... asianml W163 M-Class 15 11-13-2007 09:55 AM
    113 automatic gear whine lynch racing V-Class 3 02-24-2007 01:15 PM
    Gear whine when NOT in low range hawaiibenz W163 M-Class 7 11-26-2006 03:26 AM
    Gear Whine/Bearing Whine? DOUGLAS MARTIN W123 E,CE,D,CD,TD,TE Class 2 05-14-2006 06:23 PM
    4matic gear whine 1990 300E milhan W124 E,CE,D,TD Class 0 11-08-2004 02:38 PM
