W114 280CE Gearbox Dipstick - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 11-11-2008, 12:27 AM Thread Starter
Date registered: Oct 2008
Hello All,
After owning a 450SLC, I have added a 280CE to the collection. Very happy with it.
However, the gearbox is a little problematic, sometimes after standing in the traffic, it would not pull away in gear until changing to N and then D again.
I looked at the gearbox oil dipstick. There are two humps, the car was hot, driving for 6 miles and left in P and handbrake for 5 minutes.
The oil level is below the bottom hump, what does the two humps mean? Top one is the one I should fill up to?
I would really appreciate your help.
01alam is offline
post #2 of 2 (permalink) Old 11-30-2008, 07:23 AM
Date registered: Oct 2007
Vehicle: 30+ mercedes and a suburban to tow them
transmission fluid expands when warmed up. The cold level on the dipstick can look a lot lower than the warm level, so one usually checks it warm, but not after a hard ride.
Park the car on a level surface and put the emergency brake on. Then cycle the transmission through all its gears (a second or two per gear is fine). Put it back in park before checking the fluid level.
That said, there should be a section on the dipstick with cross-hatched lines. That is the operating range for your fluid level. Below that area, put more in (Dextron will do). Try not to add more than 8 ounces (half a pint) at a time. Let the new fluid warm up before adding more.
cth350 is offline
    Gearbox Dipstick on W114 280CE 01alam W123 E,CE,D,CD,TD,TE Class 5 11-16-2008 04:52 AM
    w114 280ce still sorting out D_R_Payne Vintage Mercedes-Benz 5 03-04-2007 01:52 PM
    Newbie and W114 280ce D_R_Payne Vintage Mercedes-Benz 12 02-06-2007 08:17 AM
    w114 280ce desmopressin Vintage Mercedes-Benz 0 04-29-2006 02:09 AM
    W114 280E vs W123 280CE StreekG Vintage Mercedes-Benz 4 02-11-2006 01:55 AM
