Air Intake filling up with gasoline - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 11-10-2008, 02:18 PM Thread Starter
Date registered: Nov 2008
I have a 1974 450SL -
I was checking fuel pressure and the cold start valve and happened to look at air intake and it was almost filled to the top with gasoline. Quickly turned off ignition and siphoned gasoline out of engine block. Wife not happy with smell in garage.
Any thoughts on the cause? My first thought is a stuck (open) injector or the computer has gone bonkers and is commanding one or more injectors open even though engine is not running.
gator70uf is offline
post #2 of 5 (permalink) Old 11-30-2008, 08:31 AM
Date registered: Oct 2007
Vehicle: 30+ mercedes and a suburban to tow them
A stuck injector would sure do it.
Before proceeding, check the status of your insurance on the garage and its contents along with the location of fire extinguishers. Nothing like a little excess gasoline to raise your blood pressure 20 points and to remind you that fires are really bad things to have happen to nice cars. ((OK maybe I'm kidding about the insurance, but you do have a fire extingusher or two handy, right?))
Your engine won't like to drink that much gasoline. Pull the plugs and let the cylinders air out too. If you do have a cylinder full of gasoline, hand crank the motor to get most of it out. Also, be prepared to change your oil before running the engine, since fuel will seep past the rings and polute the oil pretty quickly.
Your next step to restoring the car to driving health is to remove the injectors from the intake and test fire them. If you are a parts junkie like me, you'd have enough spare hoses, fuel pumps, switches, etc to be able to rig up a spare fuel pump and run kerosene through it. Using it to flush the injectors and monitor the spray patterns is much safer than doing that with gasoline.
When ordering spare parts, be sure to get a full set of the large and small injector seals (one of each per injector). It's a good time to replace them.
-CTH
cth350 is offline
post #3 of 5 (permalink) Old 11-30-2008, 10:13 AM Thread Starter
Thanks - All good ideas - and I do have several fire extinguishers
post #4 of 5 (permalink) Old 11-30-2008, 03:04 PM
Date registered: Jun 2004
Quoted: 6 Post(s)
For the intake to fill up,the cold start injector is stuck open. The car must have pretty smokey for this to occur. I would check the cold start injector before proceeding further.
mercmad6.3 is offline
post #5 of 5 (permalink) Old 12-01-2008, 04:53 AM
that is definitely an easy place to start, since you can disconnect it and plug the dangling line with a fuel pressure gauge. -CTH
cth350 is offline
    Air Intake Boot Below Air Flow Meter bottom diameter? Teutone W126 S,SE,SEC,SEL,SD,SDL Class 3 04-28-2008 11:42 PM
    Gasoline leak when filling up tank! Please help! deyainrdy4ds C208/A208 CLK-Class 20 09-24-2007 01:58 PM
    air filter/ gasoline harvsc280 General Mercedes-Benz 1 11-29-2004 07:21 PM
    Tom, at parts.com, is "Air Intake, Adapter, Gasket" same as the air inlet tube? Andy R170 SLK-Class 4 03-30-2002 03:22 AM
    Cold Air Intake/Intake OPTIONS FOR CLK320 Please Help! Anthony C208/A208 CLK-Class 7 03-04-2002 01:36 PM
