68 250 se heater control - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 11-05-2008, 06:04 PM Thread Starter
Date registered: Nov 2008
Vehicle: 1968 250 SE
Hi, Folks Picked up a pretty neat old mb with body in good shape. Runs, but will be asking some carb questions. At this point, we need to get the heater control working as it runs good enough to drive, but November on the north coast can be a tad brutal. I haven't gone in there with a mirror yet, but what's the magic trick to get the controls out of the dash. This car has ac. Thanks in advance for any help. Al DeVo
alandevo is offline
post #2 of 3 (permalink) Old 11-05-2008, 08:59 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 95 Post(s)
I pulled the dash in my 280, and started with the glove box and door. I also took off the AC panel (be careful with the wire sensor), the ash tray, knobs and radio, and took off the wood dash panels one by one. After it's all out, you have access to the sliders and the inside guts of the dash.
Grubeguy is offline
post #3 of 3 (permalink) Old 11-06-2008, 03:31 PM
Peoria Benz's Avatar
Date registered: Jul 2006
It's been a few years, but the radio, dash speaker and glove box should be removed. Unhook the cables (without losing the cable clips), disconnect the electrical connection, remove the 10mm nuts that secure the unit to the dash via the trim plate. Then the whole unit should come out through the speaker hole. Patience helps. Good luck.
Peoria Benz is offline
    Climate control/heater Rahray W124 E,CE,D,TD Class 11 04-24-2008 11:03 PM
    sunroof control panel on my 250 D peter2463 W124 E,CE,D,TD Class 2 07-18-2005 02:45 PM
    Wood dash trim and heater levers for 230, 250, 280SL Hausof280SL Vintage Mercedes-Benz 0 02-02-2004 02:52 PM
    Need help with the heater control please!!!!!! 1982 AMG W126 S,SE,SEC,SEL,SD,SDL Class 7 01-16-2003 07:48 PM
    Heater Control Valve Guest (MBNZ) W201 190-Class 1 05-30-2001 11:18 AM
