1964 190c wiring diagrams - Page 2 - Mercedes-Benz Forum
post #11 of 13 (permalink) Old 11-07-2008, 02:30 AM
Date registered: Jun 2004
Quoted: 5 Post(s)
Why replace the loom or remove earth points? .I have piles of old looms here for all sorts of Mercs right up to 1990 W126's and all are perfectly servicible. Sometimes the insulation on the ends of leads gets affected by heat on FI engines and the cotton braiding becomes dirty but otherwise the looms will last forever. We are dealing with Daimler Benz here guys not GM. The reason Mercedes have those seperate earth points is for assembly purposes when the cars are being built and reliability, If it were a lesser make the body would be the main earth connection with earth return via the various fittings which always give problems. I have always found electrical problems on Mercedes are ALWAYS the components on the end of the wire.. Never the wire itself.I discount component abuse and stupidity such as overloading circuits with pieces of wire instead of fuses and halfwit stereo installers .
mercmad6.3 is offline
post #12 of 13 (permalink) Old 11-07-2008, 02:16 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 95 Post(s)
I would agree up to a point. While I'm a huge fan of Mercedes engineering and reliability, the wiring in my Benz became brittle, and the insulation started cracking. While the copper inside doesn't dissolve, it tended to short out in time. I had replaced the loom once, and it aleviated a lot of smaller problems that I couldn't trace down ...
Grubeguy is offline
post #13 of 13 (permalink) Old 03-22-2009, 01:52 PM
Date registered: Mar 2009
Searching for 66 200D wiring diagram
Anyone have any leads?
rjdelbueno is offline
    In need of wiring diagrams secretmachine W124 E,CE,D,TD Class 2 07-14-2008 10:27 PM
    wiring diagrams? 230emercedes General Mercedes-Benz 6 01-25-2005 04:53 AM
    wiring Diagrams myfirstbenz Vintage Mercedes-Benz 0 03-23-2004 10:54 PM
    Wiring diagrams + Guest (MBNZ) General Mercedes-Benz 1 10-25-2000 06:32 AM
    Wiring diagrams + Guest (MBNZ) Vintage Mercedes-Benz 1 10-25-2000 06:32 AM
