inspection failed due to unbalanced front brakes - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 10-28-2008, 08:37 PM Thread Starter
GGR
Date registered: Apr 2006
Vehicle: W111 Coupe
Quoted: 19 Post(s)
Dear All,
today I brought my Coupe 3.5 to inspection in view of registering it. Evereithing was fine apart form the front left brake which is less powerful than the right one. Calipers have been overhauled, disks and hoses are new, I bleeded both sides but the problem remains. The pedal is a bit soft. Any Idea where I should look first?
In case I fail to sort it out myself, who is doing a good job on these cars in or around Washington DC?
Thanks in advance
Gael
GGR is offline
post #2 of 6 (permalink) Old 10-28-2008, 09:43 PM
PWogaman's Avatar
Vehicle: 80 280SL, 85 300SD, 87 300TD, 90 300TE 4Matic, 90 300D 2.5 Turbo, 92 300D 2.5 Turbo, 92 300TE 4Mat
Quoted: 29 Post(s)
It could be as simple as needing to bled your brake lines. Spongy pressure would be consistent with that. It might be a good time to flush your brake lines if you haven't done that within the last couple of years. If your brake lines have been bled properly then the problem could be in the master cylinder.
Current
80 280SL
85 300SD
87 300TD 2Matic
90 300TE 4Matic
90 300D 2.5 Turbo 2Matic
92 300D 2.5 Turbo 2Matic
92 300TE 4Matic
01 Saab 9-5 Wagon FrontWheelDriveMatic
Former
91 300E 4Matic; 96 Dodge Grand Caravan; 76 450SL; 77 350SLC; 87 VW Cabriolet; 87 VW Golf GL; 88 Ford Ranger; 80 VW Rabbit; 80 Dodge Ramcharger Snow Commander; 75 Simca; 67 VW Beetle; 59 Bultaco; 57 VW Beetle; Honda CX500; Kawasaki 250; Honda CB50
PWogaman is offline
post #3 of 6 (permalink) Old 10-29-2008, 09:24 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 99 Post(s)
I'd say master cylinder as well. You say you bleeded both sides, right Gael?
Grubeguy is offline
post #4 of 6 (permalink) Old 11-01-2008, 07:59 PM
Date registered: Jan 2007
Quoted: 82 Post(s)
I agree that you should bleed the brakes to get rid of the soft pedal.
JCP Motorsports in Alexandria, American Service Center in Arlington, and Don Pool in Falls Church are about the only reliable places for work on older cars.
Chuck Taylor
Falls Church VA
1998 SL500
1959 220S
1970 280SL
ctaylor738 is offline
post #5 of 6 (permalink) Old 11-01-2008, 09:03 PM
wbain's Avatar
Date registered: Dec 2003
I spoke to Gael, a Frenchman, and he also sent me a message. The problem is that the intermediate brake pipe between the front caliper and the brake hose was replaced at some time with a home made version. This home made version was not properly attached and developed a stress fracture causing a brake fluid leak. The car faile DC inspection because of the leak.
Gael went to the dealer in Bethesda who told him the brake pipe is NLA. I e-mailed Tom Hanson at the Classic Center who said the dealer was wrong and that both left and right are available and supplied part numbers. I spoke to Gael, gave him the part numbers and he will order and install them.
wbain is offline
post #6 of 6 (permalink) Old 11-05-2008, 11:08 AM
PWogaman's Avatar
Quoted: 29 Post(s)
Shockingly, it appears the D.C. inspection system worked, as intended!
Current
80 280SL
85 300SD
87 300TD 2Matic
90 300TE 4Matic
92 300TE 4Matic
Former
PWogaman is offline
    Failed inspection AlanS W124 E,CE,D,TD Class 3 06-26-2008 07:34 AM
    Fairly Unbalanced or just Unbalanced? You Decide. mcbear Off-Topic 26 02-06-2008 09:12 AM
    Failed inspection due to "bad" ball joints at 32K saxmanjack R170 SLK-Class 9 06-11-2007 04:46 PM
    Help! I failed emissions inspection! bigdaddyd300se W126 S,SE,SEC,SEL,SD,SDL Class 22 05-19-2006 06:52 PM
    Need Help-Failed NJ Inspection Feyms@aol.com R129 SL-Class 3 11-27-2004 10:30 AM
