72 280sel - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 10-25-2008, 12:33 PM Thread Starter
Date registered: Oct 2008
Vehicle: 280sel
72 280sel
i just changed my fuel pump and checked the filter and its all ok and im still not getting any fuel pressure ?????
what do i do?
mprider is offline
post #2 of 10 (permalink) Old 10-25-2008, 01:24 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 99 Post(s)
Is your pump getting voltage? When you first turn the key on, do you hear the pump run for a second or two? If not, check the relay, the fuse and of course, wiring.
Grubeguy is offline
post #3 of 10 (permalink) Old 10-25-2008, 05:31 PM
wbain's Avatar
Date registered: Dec 2003
6 cyl or V-8? In other words, mechanical FI or EFI?
wbain is offline
post #4 of 10 (permalink) Old 10-25-2008, 09:32 PM
Date registered: Dec 2004
Vehicle: 1972 280CE
Quoted: 109 Post(s)
First thing first, check if the fuel pump is running. If not then it's electrical. You can take a battery booster and jump the pump.
If the pump is running. Then you probably have a blockage in the tank. Remove the fuel line to the pump and see if there is any fuel coming out.
With best regards
Al
Check out the W114, W115 /8 enthusiast forum http://www.stroke8.org
My 280SL restoration
alabbasi is offline
post #5 of 10 (permalink) Old 10-26-2008, 05:29 AM
Date registered: Jun 2004
Quoted: 6 Post(s)
what do i do?
280SEL. It's a six clyinder MFI equipped W109 with steel springs.
The tank has a fuel filter in the drain bung . There is also a filter and ball valve in the pump it'self.
mercmad6.3 is offline
post #6 of 10 (permalink) Old 10-26-2008, 02:20 PM Thread Starter
Vehicle: 280sel
its a v8 and the pump turns on once i turn the key
mprider is offline
post #7 of 10 (permalink) Old 10-26-2008, 02:42 PM Thread Starter
Vehicle: 280sel
what would i have to do if there was a blockage in the tank??
mprider is offline
post #8 of 10 (permalink) Old 10-27-2008, 01:03 AM
wbain's Avatar
That would be a W108. It's a 280SEL 4.5.
As for the fuel flow, the tank cab be checked from the trunk. The fuel level sensor bolts on top of the tank and is covered by a plastic cap on the trunk floor. Look insode, the pickup could be blocked.
wbain is offline
post #9 of 10 (permalink) Old 10-27-2008, 10:45 AM
Grubeguy's Avatar
Quoted: 99 Post(s)
I agree - inside the tank is a wire mesh screen that might be clogged. If the pump runs, and it's a new pump, it sounds like you have a blockage in the lines or in the tank.
Grubeguy is offline
post #10 of 10 (permalink) Old 11-02-2008, 12:17 PM
Remove and clean tank, then replace ALL rubber hoses, clean and purge the remaining system.
Brian O
bostosh is offline
    Anyone else with 81-85 280sel ? RevJD W126 S,SE,SEC,SEL,SD,SDL Class 22 03-31-2009 12:26 AM
    280SEL Hemersam W126 S,SE,SEC,SEL,SD,SDL Class 3 08-30-2007 12:21 PM
    '85 280SEL Hemersam For Sale/Wanted/Trade/Giveaway 1 08-29-2007 08:53 PM
    1973 280SEL 4.5 MBZ300CD Vintage Mercedes-Benz 13 09-03-2006 02:18 PM
    280SEL? BILLSONG W116 S, SE, SEL, SD Class 1 10-28-2005 05:38 PM
