New VDO tachometer in a 1970 280SEL? - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 10-15-2008, 09:44 AM Thread Starter
DC Hughes's Avatar
Date registered: Sep 2008
Vehicle: 1970 280SEL, 1981 240D, 1978 Z28
Question New VDO tachometer in a 1970 280SEL?
I have a new VDO tachometer I am trying to install on my 1970 280SEL with the transitorized ignition. I have tried connecting it as the VDO instructions say to the negative coil terminal, but nothing happens. Any help on where to make the read connection to would be much appreciated
DC Hughes is offline
post #2 of 5 (permalink) Old 10-18-2008, 12:53 PM
Date registered: Jan 2007
Quoted: 85 Post(s)
I think you have the setup where the negative side of the coil is simply grounded. Follow the wire from the points and you should find a terminal block where it connects to a green/yellow wire from the transistor box. Try connecting the tach there.
Chuck Taylor
Falls Church VA
1998 SL500
1959 220S
1970 280SL
ctaylor738 is offline
post #3 of 5 (permalink) Old 11-06-2008, 08:46 AM Thread Starter
DC Hughes's Avatar
Question
I connected there, but get a bad reading. I even tried adjusting the tach itself but not accurate at all.
post #4 of 5 (permalink) Old 11-06-2008, 11:53 PM
Date registered: Jun 2004
Quoted: 7 Post(s)
What sort of bad reading? .Most mercedes tacho's take the take signal from a terminal ( green wire with yellow tracer ) within the electronic boxes circuit. For older style electronic switching you may need to add a 50 ohm resistor into the circuit to even out the pulses.
mercmad6.3 is offline
post #5 of 5 (permalink) Old 11-07-2008, 06:06 AM Thread Starter
DC Hughes's Avatar
Post READING
the tach only moved between "0" and "1000" RPM, rather it was revved up or idling. I will take a look at that wiring again and maybe try the resitor too. Thanks!
    "VDO" LED Guest (MBNZ) W210 E50 AMG, E55 AMG 2 10-23-2010 02:39 AM
    BLINKER TRANSMITTER LOCATION W108 1970 280SEL DC Hughes Vintage Mercedes-Benz 5 12-12-2008 12:05 PM
    1970 280SEL smoking probs chala Vintage Mercedes-Benz 1 11-13-2007 06:15 PM
    Vdo? ML430-OFFROAD W163 M-Class 14 05-23-2007 09:31 PM
    VDO Tachometer information - Finally found it!! Thomas Schumacher G-Class 0 09-08-2002 08:48 AM
