'73 280SE 4.5 Intermittently running rich - Page 4 - Mercedes-Benz Forum
post #31 of 35 (permalink) Old 11-09-2008, 12:57 PM
Map sensor adjustment
Counter intuitive,
Unscrew will lean total mixture,
Think of the MAP sensor as an altitude compensator,
that screw raises or lowers the "set" altitude of the entire system.
This analog system operates on the difference of vacuum / pressures.
No more than 1/8 of a turn per tank of fuel.
Add 1 Qt of ATF per tankful.
Also Idle mixture will need adjustment too.
I have spare MAP sensors for substitution and messing with so as to not disturb your original as-is calibrations..
Brian O
bostosh is offline
post #32 of 35 (permalink) Old 08-05-2013, 11:00 PM
Date registered: Feb 2012
Vehicle: 2006 C230 Sprots V6, 1972 280 SEL 4.5
Originally Posted by bostosh View Post
Counter intuitive,
Hello,
I realize that this is an old post but I am having problems with the idling of my 72' 280SEL 4.5. I was curious to know what you mean by "No more than 1/8 of a turn per tank of fuel. Add 1 Qt of ATF per tankful." I feel that either the Idle control valve or air regulator of my W108 is faulty. My air regulator may be stuck and my Idle Control Valve may need cleaning. For the mean time, I've bypassed the air regulator by inserting a ball bearing from the hose that connects to air regulator to the idle control. It's a temporary fix pending the idle control valve cleaning. It has lowered the idle to where I can control idle via the idle control valve adjusting screw. The Oil pressure has dropped to 15 from 45 on the instrument cluster. I haven't tested gas readings as I don't have a gas analyzer. Hopefully a local smog shop can help me with this. Any help will be greatly appreciated. Thanks in advance.
wfd1 is offline
post #33 of 35 (permalink) Old 08-06-2013, 07:30 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
the pressure sensor [ map ] is the main fuel mix control together with the coolant temp sensor .a bad brain will cause engine to flood at time , usually when getting warm .i have seen cars with fuel running out of exhaust pipe ! . if you are in san diego , send me a phone number .
agillot is offline
post #34 of 35 (permalink) Old 08-07-2013, 07:38 AM
Premium Member
Quoted: 59 Post(s)
Premium Member
disconnect the trottle valve switch , and see if problem goes away , you can drive that way for testing .i am in bonita .
agillot is offline
post #35 of 35 (permalink) Old 08-07-2013, 08:11 AM
I haven't tried that yet. I'm located in San Francisco.
wfd1 is offline
Running Lean / Intermittently jsscls450sl R/C107 SL/SLC Class 7 08-05-2008 08:02 AM
Running VERY Rich Jayare W124 E,CE,D,TD Class 8 05-18-2008 09:26 AM
running too rich ogGQ W126 S,SE,SEC,SEL,SD,SDL Class 23 04-30-2008 07:43 PM
Running too rich benjisbenz W126 S,SE,SEC,SEL,SD,SDL Class 2 09-21-2004 01:44 PM
running rich Guest (MBNZ) General Mercedes-Benz 0 02-10-2002 04:16 AM
