Groaning noise when turning - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 10-09-2008, 10:46 AM Thread Starter
Date registered: Aug 2008
I am the relatively new owner of a 1972 280 SEL 4.5L There is a groaning/whining noise when I turn, particularly noticeable at low speeds. It is not tire noise, it sounds to me like the power steering pump, though it may be other suspension items. Is this normal? The power steering has fluid. There is no odd steering feedback. The car has recently been lubed with fresh grease. Any ideas on what if anything I should do? thanks
robert!@# is offline
post #2 of 3 (permalink) Old 10-09-2008, 02:20 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 95 Post(s)
Nope, not normal. Mine doesn't do that. Is it only one direction, or does the groan happen while turning in either direction? Two things come to mind - wheel bearings and the power steering pump. When stopped and turning the wheel, do you hear anything?
Grubeguy is offline
post #3 of 3 (permalink) Old 10-09-2008, 03:59 PM
Date registered: Feb 2008
Vehicle: 2004 W220 (S430) ; 2001 R129 (SL500) Sport
Location: Alabama Gulf Coast--formerly Charlottesville, VA
I'd bet PS pump. Check the fluid level and the fittings for leakage. The W108 I had 25 years ago had chronic PS pump problems. The cover seal sometimes leaks, and the metal to rubber fitting on the hoses are also problem areas. That's a 25 year-old memory, but I hope it helps.
"Don't pick a fight with an old man. If he is too old to fight, he'll just kill you."--John Steinbeck
DrJfrmLA is offline
    steering wheel makes groaning noise ProV1x W210 E50 AMG, E55 AMG 13 11-13-2007 12:10 PM
    groaning sound when turning brianM W126 S,SE,SEC,SEL,SD,SDL Class 2 08-01-2007 05:23 PM
    Groaning noise when reversing djtoast W123 E,CE,D,CD,TD,TE Class 0 09-07-2006 07:09 AM
    Groaning and shuddering noise on cold start sarv W220 S-Class 1 09-22-2005 04:22 PM
    Help with Groaning noise from rear end 1983_240D W123 E,CE,D,CD,TD,TE Class 12 02-26-2005 05:44 PM
