240D oil leak? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 10-03-2008, 04:21 PM Thread Starter
Date registered: Jun 2008
240D oil leak?
Hi, This behavior seemed to start when I changed the oil. I changed the oil pretty much first thing when I bought the car since I had no idea how long it had been since it was last done. I ordered a filter from autozone, was some fram brand. The filter looked nothing like the one that was in before, but it seemed to fit fine. After a week I noticed there was some oil leaking from the filter canister so I tightened it up a bit and it seemed to stop. I never took it on the highway for about a month (pretty much always under 45mph). Now I must drive daily ~30miles on the highway (~65mph). After the first drive I noticed the oil level went down from about halfway between the marks to near the very end of stick after only 30 miles! I can't see how the engine could be burning the oil (engine is not smoking, no oil in the exhaust).
So yea... I guess it must be leaking. Should I order a proper filter and hope that it has better seals? Is there some other trick I am missing?
bagawk is offline
post #2 of 4 (permalink) Old 10-04-2008, 05:24 AM
Date registered: Jan 2004
Quoted: 30 Post(s)
I would suggest that you buy the correct OE filter. That would mean a Mann, Hengst, Knecht/Mahle or a Mercedes boxed filter. They come with an O ring that needs to be replaced each time the oil is changed. The old O ring must be removed too. Don't leave two of them in there. It will leak with zero or two O rings. You can change the filter now without having to drain the oil you just changed. If it is leaking, however, you ought to see evidence of that.
sokoloff is offline
post #3 of 4 (permalink) Old 10-04-2008, 03:56 PM
Vehicle: 2000 ML320, 2005C240 4matic wagon, 1962 220SEb, 2002 CLK55 Cabrio, 2014 C300 4matic, 2000 CLK55
Quoted: 2 Post(s)
You may want to check if during your last filter change you removed the old o ring from the filter housing before installing the new o ring. The grove on the filter housing is deep enough to accomodate 2 orings at a time. If you did not remove the old o ring the stacked o ring configuration is no match for 45+ psi from the oil pump.
yaki b is offline
post #4 of 4 (permalink) Old 10-04-2008, 07:10 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 544 Post(s)
^ +1. I've heard that one quite a bit.
GeeS is offline
    Oil Change in 81 240d cause lack of power and lower oil PSI? Cobb2 W123 E,CE,D,CD,TD,TE Class 12 07-15-2008 10:51 PM
    ** Help ** 81 240D oil leak Cyberbach W123 E,CE,D,CD,TD,TE Class 15 10-24-2007 05:09 PM
    Wiring loom - insulation falling off, water leak, oil leak sjc123456789 W124 E,CE,D,TD Class 3 02-10-2006 10:24 AM
    oil leak... motor honey?...leak stop? b2d W123 E,CE,D,CD,TD,TE Class 1 04-11-2005 03:07 PM
    My car is in the shop...Oil leak, windshield washer leak, and screw came off. chanm W163 M-Class 3 05-23-2003 06:21 AM
