BLINKER TRANSMITTER LOCATION W108 1970 280SEL - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 10-02-2008, 12:49 PM Thread Starter
DC Hughes's Avatar
Date registered: Sep 2008
Vehicle: 1970 280SEL, 1981 240D, 1978 Z28
Post BLINKER TRANSMITTER LOCATION W108 1970 280SEL
Does anyone know where the blinker transmitter is located on a w108 1970 280sel? It should be seperate from the emergency flasher.
DC Hughes is offline
post #2 of 6 (permalink) Old 10-05-2008, 04:51 AM
Date registered: Jun 2004
Quoted: 7 Post(s)
Smile
Why shouldn't it be? because that is exactly where it is. :-)
mercmad6.3 is offline
post #3 of 6 (permalink) Old 10-06-2008, 03:37 PM Thread Starter
DC Hughes's Avatar
The emergency flashers still work. Others have told me that some cars had seperate flashers for the turn signals.
post #4 of 6 (permalink) Old 10-06-2008, 06:52 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 102 Post(s)
Glad to hear the emergency and normal signal lights share the same flasher - I replaced mine a while ago. Glad to hear I wasn't taken for a ride!
Grubeguy is offline
post #5 of 6 (permalink) Old 10-15-2008, 09:26 AM Thread Starter
DC Hughes's Avatar
Post Fixed for now.
I did trace the wiring diagram and the emergency flasher switch is tied to the turn signals. So I was going to remove the emergency flasher switch from the dash for inspection and decided to try the signals one more time before removing it and they began working again. I guess a little wiggle and push was all that was needed for now.
post #6 of 6 (permalink) Old 12-12-2008, 12:05 PM
Date registered: Oct 2008
Vehicle: 1972 280SEL 4.5
My 72 280SEL uses two flashers. One for the turn signals located under the dash on the drivers side and one for the emergency flashers which is contained in the switch itself.
A note on the turn flasher. If it is the correct part, you will find a small hole on the bottom between the prongs. This is an access port to adjust the flash rate. Leave it to Mercedes to put an adjustment into the turn signals. Makes sense though if you consider how far you would travel on the autoban between flashes. Need high speed for that application.
o-gauge_steamer is offline
    wanted windshield for 1971 280sel (w108) Rauchen For Sale/Wanted/Trade/Giveaway 1 07-25-2008 02:32 PM
    Idle problem for W108 280SEL (3.5) from 1971....Please help ESOOO Vintage Mercedes-Benz 3 03-30-2008 01:07 PM
    1970 280SEL smoking probs chala Vintage Mercedes-Benz 1 11-13-2007 06:15 PM
    >>> A few W108, 280SEL 3.5 Question...Need help. ESOOO Vintage Mercedes-Benz 3 09-03-2007 04:51 AM
    280SEL W108 Injection settings. wan.7 Vintage Mercedes-Benz 2 10-08-2006 08:43 PM
