power window regulator - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 09-30-2008, 03:18 PM Thread Starter
Rauchen's Avatar
Date registered: Jul 2008
Vehicle: 1971 Mercedes 280sel (w108)
I have a 1971 280SEL. I need a cheap front driver side power window regulator. My question is will only regulators from the 108 fit this or years 68-72? Or are there any newer models, from which a regulator will fit mine? Obviously the newer the model the cheaper they seem to be. The motor I have works fine, but somebody removed the whole regulator before I bought the car.
Rauchen is offline
post #2 of 5 (permalink) Old 10-01-2008, 08:29 AM
E-Class Owner's Avatar
Vehicle: 2003 Mercedes Benz E500
If I recall correctly...
The later W108/109 power window regulator is specific to that chassis.
Rather than being a stamped steel unit, yours has an alloy assembly to which the arm, motor, etc. are mounted. The alloy cracks over time due to the high torque of the motor and the tendency for some owners to hold the switch for a little longer than required to close the window.
I don't know of any substitutes... and yes, they are not cheap. You might want to be on the lookout for a good used piece.
Good luck,
JR
E-Class Owner is offline
post #3 of 5 (permalink) Old 10-01-2008, 10:59 AM Thread Starter
Rauchen's Avatar
That's kinda what I thought. And yeah, I'm lookin' for a used one if I acn find one. New one $150 min. Thanks for the input, I appreciate it.
Rauchen is offline
post #4 of 5 (permalink) Old 10-05-2008, 04:56 AM
Date registered: Jun 2004
Quoted: 17 Post(s)
Early ones (Steel frame ,seperate motor with 3 wires) are no longer available from Mercedes,so you can fit the later alloy frame ,2 wire motor ,assembly .
BUT,you need to assemble a couple of relays to enable the motor to work. Mercedes sent out a worksheet back in the 1980's describing how to wire the relays . it's simple enough ,it just allows the power to switch from wire to the other .
mercmad6.3 is offline
post #5 of 5 (permalink) Old 10-06-2008, 09:19 AM Thread Starter
Rauchen's Avatar
do you mean relays other than under the hood? All the other windows work fine, I assumed they all went thru the same relay. Is there ones in the door that I would have over looked?
Rauchen is offline
Window regulator winecountry400E W201 190-Class 0 04-02-2008 07:09 PM
e320 rear window regulator / window motor failure 60bugeye General Mercedes-Benz 6 08-19-2007 05:59 PM
window regulator mokgongee For Sale/Wanted/Trade/Giveaway 1 01-30-2007 04:54 PM
Driver Side Window Regulator, Window Sliding Bracket broken ranjitsml320 W163 M-Class 6 06-25-2006 11:46 PM
Window Regulator memphise320 W210 E-Class 1 09-03-2004 01:32 PM
