Carb options, w115, any thoughts? - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 09-27-2008, 12:35 PM Thread Starter
Date registered: Sep 2008
Vehicle: 1972 Mercedes 200
Hey everyone, I'm a complete newbie to the vintage Mercedes world. I just picked up a very clean '72 200. Once warm it runs like a top, but for the first 10 minutes or so it runs terribly, wanting to die every time I let of the throttle, idling rough, etc. Is this just a matter of it needing a serious tune up and carb cleaning? I'm still learning how to work with Carbs but I was told that it sounds like it might be running rich. I've also been told that the Stromberg Carbs are generally a pain, and that swapping to a Weber is a popular mod. Anyway, any thoughts? Thanks
42ndRHRfifer is offline
post #2 of 8 (permalink) Old 09-27-2008, 01:54 PM
Eirik 400 SE's Avatar
Date registered: Jan 2008
Vehicle: 1973 W115 200 /8
A thing to check is the membrane inside the top of the carb.. It should be tight, and without cracks..
The mixture is adjusted with the screw UNDER the main house.. IN/UP=leaner mixture and OUT/DOWN= Richer mixture.
The idle is adjusted with the screw right at the side.. NOT the lever from under the carb..
Is there enough oil in the carb ?
Is the automatic choke adjusted correctly ?
Is the ignition OK ? Dwell/Cam angle and timing ?
There's a LOT that could be off.. which would give symptoms of bad fuelconsumption, smoke, rough idle etc etc..
1991 W140 400 SE - SOLD !!
1973 W115 200 -For sale as project.
Eirik 400 SE is offline
post #3 of 8 (permalink) Old 09-28-2008, 11:03 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 99 Post(s)
The Weber mod is an easy one to do - I did it with a 280C, replacing the original Solex carb. It didn't present any huge issues, but the original carb was a much better one, and I ended up regretting the replacement. I went from about 18 mpg on the highway to 12, even with the Weber leaned way out. I would suggest you take yours apart, clean it, do all the tuneup stuff, and see what you have once it all gets put back together.
Grubeguy is offline
post #4 of 8 (permalink) Old 09-28-2008, 12:01 PM
Only thing.. The Stromberg is a SIDE-carb.. And Solex and Weber are usually DOWN...
The 280 C had most likely 2 carbs. They're an easy fix..
The Stromberg replacement could mean a new intake-manifold..
post #5 of 8 (permalink) Old 09-28-2008, 08:10 PM
E-Class Owner's Avatar
Vehicle: 2003 Mercedes Benz E500
The 280C,
M110, in non-FI form, had a four barrel down-draft carb. IIRC both Weber and Solex [especially Mikuni licensed ones] are available as side draft units; that said, I would work on getting the OE carb fixed/re-built as opposed to adding an after-market unit to the mix.
Good luck,
JR
E-Class Owner is offline
post #6 of 8 (permalink) Old 09-29-2008, 10:19 AM
patrick800's Avatar
Date registered: Aug 2006
Vehicle: 1973 MB 280C (sold), 1976 MB 300D, 2009 VW CC 4motion
I had a 73 280C with the 4 barrel solex carb, a real PITA. I replaced it with a weber, had a horrible flat spot. IMHO the weber is not a bad carb but is simply not adapted to these cars, better to stick with original carb.
I now have a fuel injected diesel 115 and I dont miss these old carbs one bit!
patrick800 is offline
post #7 of 8 (permalink) Old 09-30-2008, 06:26 PM Thread Starter
Yup, I've got a Stromberg sidedraft carb. I knew that any weber swap would have to be a DCOE or something along those lines and would require the manifold and everything. But from the sounds of it, it looks like I'm ordering a rebuild kit this week. One more question. Ive found a couple sites that carry basic rebuild kits, and a couple also carry a complete overhaul kit with new jets and everything. Is there any particular reason for this? Are these carbs known to wear out their internals, or should I probably be good with a normal rebuild. Thanks
post #8 of 8 (permalink) Old 10-01-2008, 02:26 AM
I just ordered a complete set from Mercedes.
A0015861107 was the part number I needed for my Stromberg carb..
    Interesting information on my car, any thoughts on these options? slybydesign W210 E-Class 5 08-08-2007 03:30 PM
    V8 FI to Carb dubnluvn Vintage Mercedes-Benz 4 08-21-2006 09:53 PM
    Wheel options - possibly more options mb230s G-Class 3 12-10-2004 10:31 AM
    Lowenhart LDR Replicas.... want some thoughts on options (READ ALL!) jtoma878 C208/A208 CLK-Class 8 08-30-2004 04:34 PM
    To Tim, Norb, Brian and Calvin (Options Options Options) Matthew R170 SLK-Class 9 12-19-2000 08:13 PM
