Fuel Injection Pump - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 09-10-2008, 07:50 PM Thread Starter
Date registered: Sep 2008
Vehicle: 560 SEL and 220 SEB Coupe
Fuel Injection Pump
The engine on the 220 SEB 1965 has not been run for at least 5 years, I was wondering if I should take it apart, clean and lubricate it before I try to start it up.
What oil should I use?
Thank you.
220SEBC is offline
post #2 of 11 (permalink) Old 09-11-2008, 07:42 AM Thread Starter
Ok. Do you mean completely take the pump apart? Any instructions on how to?
Thank you.
I read that the best oil to use is Mobil 1, is this correct?
220SEBC is offline
post #3 of 11 (permalink) Old 09-11-2008, 08:04 AM
E-Class Owner's Avatar
Vehicle: 2003 Mercedes Benz E500
No...
Thank you.
Your engine was designed for conventional oil, and the use of synthetic at this stage WILL cause oil leaks.
Do not disassemble your injection pump; they are calibrated, and you run a good chance of causing problems if you do so [assuming that you can get things back together properly...]
Fresh engine oil would be a good idea. The pump is internally lubricated by engine oil and by the fuel. These days a lead substitute additive would be a good idea as unleaded fuel is very hard on the pump and over time, will cause accelerated wear.
JR
E-Class Owner is offline
post #4 of 11 (permalink) Old 09-11-2008, 08:27 AM Thread Starter
Thank you again.
Do I have to add the oil to the pump, or is the pump supplied for the engine oil pump/circuit?
220SEBC is offline
post #5 of 11 (permalink) Old 09-12-2008, 08:40 AM
The oil...
Thank you again.
is supplied by the engine.
JR
post #6 of 11 (permalink) Old 09-12-2008, 11:30 PM
wbain's Avatar
Date registered: Dec 2003
Actually, later engines supply oil to the injection pump. There is an oil dip stick at the bottom rear of the IP and the oil level can be checked. I would suggest you change the oil.
I'd like to suggest you get the repair CD's for your car.
Classic Technical Literature
The ones you want have the Ponton data and the W111 data as well. The W111 manual sections build on the Ponton manual.
You also want the technical booklet because it has ALL the measurement data for the car. Don't leave home with out them.
For example:
Also, get the spare parts table which has the assembly view drawings for your car and helps to orient yourself to the car's construction and parts used.
wbain is offline
post #7 of 11 (permalink) Old 09-12-2008, 11:31 PM
wbain's Avatar
In which Berlin do you live?
wbain is offline
post #8 of 11 (permalink) Old 09-12-2008, 11:48 PM Thread Starter
Berlin, Germany. There are no longer two Berlins.
220SEBC is offline
post #9 of 11 (permalink) Old 09-13-2008, 06:32 AM
Date registered: Jan 2004
Quoted: 30 Post(s)
But there is a Berlin, Pennsylvania, i.e. potato chip country.
Len
sokoloff is offline
post #10 of 11 (permalink) Old 09-13-2008, 09:54 AM
wbain's Avatar
There are many towns and cities named Berlin here in the USA, but none as famous as yours. One day I will get there and see your beautiful city.
wbain is offline
    Fuel Injection Pump cchkaiban W123 E,CE,D,CD,TD,TE Class 3 04-09-2007 07:43 PM
    injection pump fuel leak. mybenz123 W123 E,CE,D,CD,TD,TE Class 0 03-31-2007 12:13 PM
    Rebuilding a fuel injection pump? Benzoid123 W123 E,CE,D,CD,TD,TE Class 12 09-30-2006 10:46 PM
    Fuel leak at injection pump...help! no-blue-screen W123 E,CE,D,CD,TD,TE Class 20 06-05-2006 05:59 AM
    Fuel injection pump for 1992 2.5 turbo ilikemercedes W124 E,CE,D,TD Class 0 11-06-2004 11:29 PM
