220 SEb. Ignition Upgrade. Pertronix? - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 09-10-2008, 03:55 PM Thread Starter
Date registered: Sep 2008
Vehicle: 560 SEL and 220 SEB Coupe
Hello: I was wondering what is recommended if I want to upgrade my ignition, which "non-points" kits are the best?
Thanks.
220SEBC is offline
post #2 of 8 (permalink) Old 09-10-2008, 04:16 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 103 Post(s)
I use Pertronix in my 108. It took me all of a half hour to install, and it made the car run much better.
Grubeguy is offline
post #3 of 8 (permalink) Old 09-10-2008, 04:41 PM Thread Starter
Thank you. I will look into it. How much did it cost you?
220SEBC is offline
post #4 of 8 (permalink) Old 09-10-2008, 05:43 PM
Grubeguy's Avatar
Quoted: 103 Post(s)
... I don't remember. I think it was $110 or so. You can't get them from the manufacturer directly though, they only sell to their distributors. I bought mine thru NAPA Auto Parts.
Grubeguy is offline
post #5 of 8 (permalink) Old 09-10-2008, 06:11 PM
MBGraham's Avatar
Date registered: Oct 2006
Vehicle: '72 350SL, '85 300D, '98 E320, '14 GLK250
Quoted: 8 Post(s)
Best place to buy, is Retrorockets. They have good technical knowledge of Pertronix and will get you help from Pertronix if needed. Contact Carl at:
Retro Rockets - PerTronix Electronic Ignition Conversion Kits and HEI Components
Won't do much more than a new set of points, but never needs adjustment.
1972 350SL 4.5L - MBGraham, near Kingston, Ontario
MBGraham is offline
post #6 of 8 (permalink) Old 09-10-2008, 06:43 PM Thread Starter
Thank you. I coincidentally came upon retrorockets when I searched for "Petronix".
Wouldnt this also help the engine run better (better sparks) - better combustion?
220SEBC is offline
post #7 of 8 (permalink) Old 09-11-2008, 07:21 AM
E-Class Owner's Avatar
Vehicle: 2003 Mercedes Benz E500
I would suggest...
that you tackle one issue at a time. Your conventional ignition will be adequate to get the engine running, as an initial step. The advantage of an electronic ignition system is foregoing the routine maintenance that goes along with the conventional ignition system, e.g. installing, gapping the points and setting the timing, etc. It is true that an electronic ignition system produces a hotter spark, but that is a secondary matter.
No offense, but I get the feeling that you are trying to tackle too many issues at once, without the requisite knowledge to do this... a "scattergun approach"... get the engine running first, and then worry about refinements.
JR
E-Class Owner is offline
post #8 of 8 (permalink) Old 09-11-2008, 07:34 AM Thread Starter
Thank you for your input. I will do as you say, get the engine running and then the rest.
220SEBC is offline
    220 SEB Converting to Carburator 220SEBC Vintage Mercedes-Benz 26 09-13-2008 09:38 AM
    Advice on 220 SEb restoration... PackerEdgerton Vintage Mercedes-Benz 4 04-26-2008 09:52 PM
    pertronix ignition/wires experience? aegir slc R/C107 SL/SLC Class 0 12-06-2007 10:37 AM
    1961 220 SEb/c - Thoughts? goldgunner Vintage Mercedes-Benz 4 08-23-2005 08:08 AM
    220 seb stock tire size? MBZ933 Vintage Mercedes-Benz 6 03-04-2005 08:17 PM
