w114 engine miss - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 08-28-2008, 07:31 PM Thread Starter
Date registered: Aug 2008
w114 engine miss
Hi! I've recently had the carbies on my 250 tuned. There is good fuel flow and pressure. All seems to be fine but under load there is a slight but persistent miss. It could be electrical but the coil, the distributor cap and the rotor are OK. So too are the leads and the plugs. If this fault is electrical, could a faulty capacitor be the cause this?
trevortrumpet is offline
post #2 of 3 (permalink) Old 08-30-2008, 12:53 AM
Date registered: Jun 2004
Quoted: 5 Post(s)
I,ve always said this "start with the basics!!"
1/ Compression or leak down test .
2/ get the ignition perfect.
3/ Valve clearance
4/Then and only then check the fuel system.
If you think about it,starting a tune up by messing with the carbs is silly if the engine cannot burn it. [:-)]
mercmad6.3 is offline
post #3 of 3 (permalink) Old 08-30-2008, 02:23 PM Thread Starter
These steps have been done. My 250 is maintained by a Merc guru (dare I say a Merc nerd) of some decades experience. He has checked all these basics and is very knowledgeable about Zenith carbs. Still this problem is baffling him.
    74 280C engine swap? w114 to V8? or other? FastKatanaBoy Vintage Mercedes-Benz 2 03-11-2008 03:49 PM
    W114 and a 250D engine?? Odrec Vintage Mercedes-Benz 14 10-17-2006 11:11 AM
    W114 71 250 Engine Question AndyD Vintage Mercedes-Benz 2 10-03-2006 07:40 AM
    '83 200T engine miss Dusty`NZ W123 E,CE,D,CD,TD,TE Class 2 09-25-2005 10:04 PM
    W114 engine help needed. Cam Vintage Mercedes-Benz 6 02-04-2005 02:02 AM
