m130 engine--fuel mod - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 08-09-2008, 10:57 AM Thread Starter
Rauchen's Avatar
Date registered: Jul 2008
Vehicle: 1971 Mercedes 280sel (w108)
I have a 1971 280 sel (108) chassis, with the m130 6-cyl. Factory was mechanical fuel injection. Before I bought it, it was switched to carburettor. Now here is the interesting part. They plugged the injection ports with spark plugs. Using the existing intake manifold, they equipped it with 1 SU HIF-6 carb.
Right in place where the old throttle body was. Also they replaced the fuel pump with a smaller one. Overall, it works very well. Starts easy, and gets up to speed (slower than it should). So I guess my question is-can there be a better modification done to make this car run like it should? I can't afford to go back to the fuel injection, even though I would love to. But those injection pumps are like $1700. Any Ideas?http://www.benzworld.org/forums/imag...s/confused.gif
Rauchen is offline
post #2 of 6 (permalink) Old 08-11-2008, 07:54 AM Thread Starter
Rauchen's Avatar
Wow I must have stumped the gurus with this one lol.
Rauchen is offline
post #3 of 6 (permalink) Old 08-11-2008, 02:25 PM
nah not stumped, that is a creative modification
Just how did they block off the MFI hole?
I have everything to go stock if you want,
how is the compression in that motor?
Is is worth the trouble to return to stock?
Brian O
bostosh is offline
post #4 of 6 (permalink) Old 08-11-2008, 03:51 PM Thread Starter
Rauchen's Avatar
The MFI hole? there is a hose that went to the injection pump. then the port holes for for each of the cyl. is blocked with spark plugs. the whole pump is gone all injection lines are gone and throttle body is gone, with just an adapter plate in its place for the SU carb. I need to take some pics of the engine to show. If you have all the parts, I would be very interested. Please let me know. The engine compression seems fine, haven't checked with tester. I'm ignorant of how little or how much trouble they might be to put back to original. Also the stock fuel pump has been changed to a much smaller one for the carb setup.
Arnold
Rauchen is offline
post #5 of 6 (permalink) Old 08-11-2008, 08:41 PM
wbain's Avatar
Date registered: Dec 2003
Personally, I wouldn't have bought the car. I might have considered it if all the parts were available.
wbain is offline
post #6 of 6 (permalink) Old 08-06-2010, 08:54 PM Thread Starter
Rauchen's Avatar
I just came upon the post while searching forums about a recent fuel pump change that I have made. But I must say wbain, I'm glad I didn't take your advice. My Mercedes is still going strong with the same SU carb adaptation. I did realize that I had too strong of a fuel pump on. It was an AC Delco from who knows what, and it finally went out. I replaced it with (the name escapes me) a universal one from O'Reilly's it was an inline 7-9 psi. In 3 weeks it burned out leaving me stranded on the road. I was still under warranty so I got another, 3 weeks later, the same thing, stranded on the road. I have now changed to a Mr. Gasket micro-electric pump, with a 2.5 to 3 psi. I think the problem before was too high pressure to the carb, causing some driving problems plus causing back pressure, which in turn burned out the fuel pump. Anyway, I hope I am right. It has only been two days but the car runs better than ever. Starts even easier, runs quieter, still kind of lame on power, but hey, it is a single SU carb.
Overall, if I had to do over again, I would still buy this car again, I have no regrets. Yes, I get frustrated, but every time I drive somewhere, and someone yells out "hey, cool car" it makes it all worth while.
Rauchen is offline
    404 Radio repower with M130 engine Archer1811 Unimog 3 06-05-2007 10:03 PM
    1970 SEL, M130/W108 90K miles No fuel to injectors skater4fun Vintage Mercedes-Benz 0 08-20-2006 12:01 PM
    Vacuum at idle for healthy M130 engine? Riquiscott Vintage Mercedes-Benz 3 09-05-2005 09:52 AM
    Engine Mod benzo13 R170 SLK-Class 2 06-24-2003 11:26 AM
    Help! I need M130 engine 2.8L six cyl Guest (MBNZ) General Mercedes-Benz 0 12-03-2000 08:00 PM
