W108 wheel interchangeability - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 08-08-2008, 08:08 PM Thread Starter
Date registered: Aug 2008
Hello, new to the MB world with a recently purchased 1972 280SEL 4.5 I am interested in the alloy wheels of the style most commonly seen on W 116 cars (though on the 300 6.3 as well). Many are for sale on ebay, but will they fit on my car? and/or is there a place to find info and charts that list things like bolt circle diameter, offset, lug size etc. by year? thanks
robert!@# is offline
post #2 of 14 (permalink) Old 08-08-2008, 10:14 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 712 Post(s)
Offset is the same on all models all through the seventies and early eighties.... Don't sweat it.
GeeS is offline
post #3 of 14 (permalink) Old 08-08-2008, 10:43 PM
wbain's Avatar
Date registered: Dec 2003
Wheels on a W126 will fit your car. I have the Bunts, the type you want, fit my W111 220S from 1965. It's only when you start getting into the later models, like W140's and up, maybe including W124's, W102;s and later, is the offset more like FWD cars.
wbain is offline
post #4 of 14 (permalink) Old 08-09-2008, 07:39 AM
Rauchen's Avatar
Date registered: Jul 2008
Vehicle: 1971 Mercedes 280sel (w108)
what about tires on those factory steel wheels. I would like the tires just a little wider, just don't know how wide is available
Rauchen is offline
post #5 of 14 (permalink) Old 08-09-2008, 10:47 AM
Date registered: Jul 2004
Vehicle: 1971 280SE 3.5 Coupe
Quoted: 8 Post(s)
Wheel site for 108's
Here is a wheel site dedicated to 108-109 wheels.
15-17 Inch Wheels for Mercedes 108-109's
I installed 16X8 chrome R129 flat face alloys on my 3.5 coupe and they look awsome. I don't think you could go any wider though. It was definitly not a bolt on operation although some wheels might be. I am selling a set of chrome long extended head wheel bolts for the flat face alloys if you are interested. I bought them before I realized I needed studs.
3.5 Tony is offline
post #6 of 14 (permalink) Old 08-09-2008, 03:35 PM
Gustav's Avatar
Date registered: Feb 2007
Vehicle: 1968 250SE
I am running 17*8.5 35ET from a '03 SL on my W108. The fronts have 15mm spacers to clear the shocks and the rear are using 10mm spacers to clear the inner body lip. I am using studs instead of lug bolts.
Maximum tire size that will fit is 235/45R17 with this set up.
Gustav is offline
post #7 of 14 (permalink) Old 08-09-2008, 06:29 PM Thread Starter
thanks very much for the help guys! and are the lugs and nuts the same too?
I've posted a new thread asking about shocks - any help there would be appriciated too - thanks again
post #8 of 14 (permalink) Old 08-10-2008, 09:53 AM
Quoted: 8 Post(s)
Lug bolts
Your car will have lug bolts but I would reccomend installing studs-even more so if you have to use spacers. The studs come in several different lengths and that way you will know you have enough threads in the hole. Nothing would ruin your day like loosing a wheel fron using too short wheel bolts.
3.5 Tony is offline
post #9 of 14 (permalink) Old 08-10-2008, 10:05 AM
Minimum thread depth = diameter of bolt
Brian O
bostosh is offline
post #10 of 14 (permalink) Old 08-10-2008, 10:16 AM
RKH
RKH's Avatar
Date registered: Apr 2008
Vehicle: Departed 1998 SL500 (and the Pano is in Bogota)
Quoted: 463 Post(s)
Also if the bolts are too long, they may interfere with the Parking brake inside the rear hub.
RKH is offline
    EZL Interchangeability - Ignition Control Module References RoadKing R129 SL-Class 45 05-17-2013 03:56 PM
    Wheel interchangeability Gazolba Vintage Mercedes-Benz 16 03-05-2011 06:23 PM
    New W108 Owner...Source for W108 Door and Window Seals? LaterApex Vintage Mercedes-Benz 5 03-24-2008 12:51 PM
    Newb Question about W202/W124 Wheel Interchangeability 94Wagenmeister W202 C-Class 1 11-29-2006 05:07 AM
    1992 300e 4matic wheel interchangeability sach The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 08-30-2005 05:09 PM
