brake problem with '77 450 sel - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 08-07-2008, 10:07 AM Thread Starter
Date registered: Aug 2008
Hey I am new to this site and to Mercedes. I recently bought a 1977 450 SEL. I have a problem with the brakes. As I drive the car the brakes build up pressure on the front brakes until it reaches the point of locking the front brakes. After that if I let it sit for a while the brakes release but then the brake peddle goes nearly to the floor and I have very little brake left. After the car is shut off for a while the problem corrects itself but then when I drive it again the whole process repeats. Has anyone else had this problem or can you tell me what is the cause. Thanks.
randy77 is offline
post #2 of 3 (permalink) Old 08-07-2008, 05:28 PM
Vehicle: 2000 ML320, 2005C240 4matic wagon, 1962 220SEb, 2002 CLK55 Cabrio, 2014 C300 4matic, 2000 CLK55
Quoted: 2 Post(s)
What do you mean when you say "it reaches the point of locking the front brakes"?
If you mean that the pedal gets hard with no braking effect then you should check for vacuum leaks leading to the brake booster as well as all inlets on the intake manifold. Also the booster diaphram may be leaking.
yaki b is offline
post #3 of 3 (permalink) Old 08-08-2008, 05:59 AM Thread Starter
Thanks for the info!
randy77 is offline
    450 SEL Kingorcus W126 S,SE,SEC,SEL,SD,SDL Class 0 10-04-2007 07:35 PM
    Fs: '79 450 Sel tenntoad For Sale/Wanted/Trade/Giveaway 2 02-19-2007 12:52 PM
    major brake problem - 1985 500 sel euro Achates W126 S,SE,SEC,SEL,SD,SDL Class 7 12-26-2003 08:34 PM
    mid 70s vs. mid 80s/ 450 SEL 6.9 and 560 SEL Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 0 03-13-2002 02:52 PM
    '79 450 SEL Guest (MBNZ) General Mercedes-Benz 2 02-18-2001 02:38 AM
