No start after petronix - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 08-02-2008, 08:11 PM Thread Starter
Dino66's Avatar
Date registered: Jul 2008
Vehicle: 1972 Mercedez Benz 250
I got rid of the points in my 72 250.I installed petronix electronic substitute. But now all i get is cranking, no start. The installation instructions are very easy to follow. It only has the two wires,neg and pos. What do I look for now?
Dino66 is offline
post #2 of 2 (permalink) Old 08-05-2008, 07:05 AM
MBGraham's Avatar
Date registered: Oct 2006
Vehicle: '72 350SL, '85 300D, '98 E320, '14 GLK250
Quoted: 8 Post(s)
Where did you connect wires?
On my '72 SL, I connected black to same connector that green used to connect to and red to 12v side of first resistor.
Also ran a ground from distributor body to battery negative. (Not really needed)
1972 350SL 4.5L - MBGraham, near Kingston, Ontario
MBGraham is offline
    What if water in Petronix ignition? karoja Unimog 3 04-17-2007 09:59 PM
    Petronix Ignitor for 404 karoja Unimog 9 12-21-2006 08:21 PM
    MSD/Petronix ignition available? Fuel Injections swap possible? sluggoa G-Class 0 12-30-2005 09:44 AM
    Hard start or second start when warm high hc level-- beware major expense Peter Seow W126 S,SE,SEC,SEL,SD,SDL Class 1 07-03-2004 06:23 PM
    Should my 1989 190e start in 2nd gear unless floor it from start? Guest (MBNZ) W201 190-Class 5 08-01-2002 12:27 PM
