Why is my 72 merc 280 sel 4.5 still overheating? - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 07-28-2008, 02:42 PM Thread Starter
Date registered: Jan 2007
My 72 280sel 4.5 has been overheating (up to about 225 degrees) when it usually stays around 190-200. It happens when I am sitting in traffic. I replaced the thermostat and waterpump and the coolant. What else could it be?
dap019 is offline
post #2 of 6 (permalink) Old 07-28-2008, 05:12 PM
Date registered: Feb 2008
Vehicle: 2004 W220 (S430) ; 2001 R129 (SL500) Sport
Location: Alabama Gulf Coast--formerly Charlottesville, VA
Check the viscous coupling on the cooling fan. As I remember from my W108 (sold 20 years ago, sadly), if that coupling packs it in, the fan will slow to almost stop when it idles. It's the opposite of the coupling locking up so it spins at water pump speed all the time. It sounds idiotic to ask, but did you put the cooling fan back on when you reinstalled everything?
"Don't pick a fight with an old man. If he is too old to fight, he'll just kill you."--John Steinbeck
DrJfrmLA is offline
post #3 of 6 (permalink) Old 07-29-2008, 11:13 AM Thread Starter
I had a mechanic install the waterpump and thermostat. The fan seems to be working fine, but I will check into the coupling. The problem was going on before I had my mechanic replace the pump and thermostat. After he replaced the pump and thermostat the overheating problem is still going on. I suppose that it is the radiator? Maybe it is clogged?
dap019 is offline
post #4 of 6 (permalink) Old 07-29-2008, 12:48 PM
Did the mechanic back flush the cooling system when he changed the coolant? It could be the radiator is clogged as you suggest. It might also be that the water passages in the engine block are corroded or blocked. Check the radiator cap; if it isn't sealing or working properly that could be a cheap-fix cause. If the temp settles back to normal once you get moving it seems more likely it's the radiator than the engine. If the hoses are good and the coolant is holding its color (not discoloring from crud in the system), then there may be calcium deposits in the radiator. If all this stuff doesn't reveal a culprit, the next step would be to have the radiator checked for blockage I would think. Rodding out or replacing a radiator isn't a breathtaking expense compared to engine work, so let's hope it is that. If there hasn't been a consistent coolant mix or you have hard water in your area (or the area where the car spent most of its time) that also points to the radiator. Good luck.
DrJfrmLA is offline
post #5 of 6 (permalink) Old 07-29-2008, 03:20 PM
Vehicle: 2000 ML320, 2005C240 4matic wagon, 1962 220SEb, 2002 CLK55 Cabrio, 2014 C300 4matic, 2000 CLK55
Quoted: 2 Post(s)
You may want to check the aux. fan in front of the radiator. The fan circuit is protected by a fuse located under the hood in a small rectangular box like fuse holder who's cover is retained by a thumb screw. Sometimes the fan can seize up. Quite often the contacts become oxidized at the point where the fuse makes contact. You can clean these contacts and replace the old fuse. You should also check the 220 switch which looks like a threaded brass fitting that has one contact wire that is ofset from the center of the switch.
yaki b is offline
post #6 of 6 (permalink) Old 07-29-2008, 06:51 PM
I didn't remember that there was an electric fan in the W108. That's an obvious place to check. A little WD-40 on the fan bearings might loosen it up if the fuse isn't blown.
DrJfrmLA is offline
    OVERHEATING AND AIR LOCK 300 SEL 1983 m_e_siddiqui@hotmail.com Benzworld Site issues forum 0 04-21-2008 09:58 PM
    Need Help For Merc 420 Sel meralynr Benzworld Site issues forum 1 06-21-2006 04:09 AM
    Replacing 280 engine with another Merc unit Roy Gardiner W126 S,SE,SEC,SEL,SD,SDL Class 1 11-14-2003 04:25 AM
    280 GE overheating? still puzzled... Greg Avril G-Class 15 10-29-2001 02:06 PM
    1991 MERC.420 SEL Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 0 02-25-2001 08:11 AM
