electrical issue on 1970 280SE - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 07-27-2008, 10:22 AM Thread Starter
Date registered: Jul 2008
hi i took a 1970 280SE in on a trade and as a favor the previous owner powerwashed the engine bay to get all the grime off before it was trailered up to me. when i got the car it would crank but would not build oil pressure and the cylinders would not fire, after calling him and finding out that he powerwashed it i tried everything that i could think of, i soaked the wires in WD40 and i switched out ignition coils on the hunch that it may have shorted out, nothing has worked so far and the wiring diagram in Chiltons dose not help. any information reguarding this problem would be most helpfull.
Thanks, Matt
edroth17 is offline
post #2 of 3 (permalink) Old 07-27-2008, 09:00 PM
Date registered: Apr 2008
Vehicle: 300sel
no run after washing
First things, is it 6 or 8 cyl?
was the ignition system functioning?
Recent tune-up?
Check inside the distributor cap for moisture.
The distributor body has drain holes and will usually drain OK
(unless the bottom of the body is caked with oil crud).
I know that if everything is good the motors can take a direct blast ,
after all it is designed to go 100mph into a blinding rainstorm.
bwostosh is offline
post #3 of 3 (permalink) Old 07-28-2008, 07:20 PM Thread Starter
its a six cylinder with MFI not that that should matter much... but when i viewed the car it ran and idled just fine, he just said that the used engine brite and powerwashed it and he was sorry for in inconvience i dont know if that helps much
edroth17 is offline
    1970 280SE For Sale Kateglea For Sale/Wanted/Trade/Giveaway 2 02-27-2008 11:21 PM
    1970-1971 280se 3.5 pagoda Vintage Mercedes-Benz 11 11-17-2005 06:46 PM
    If you know about a 1970 280SE, I need your opinions... rgarner Vintage Mercedes-Benz 1 05-22-2005 07:00 PM
    1970 280SE Guest (MBNZ) R/C107 SL/SLC Class 1 10-01-2001 08:46 AM
    1970 280SE Guest (MBNZ) General Mercedes-Benz 5 10-01-2001 08:46 AM
