Injectors for M117 - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 07-04-2008, 08:46 PM Thread Starter
MBGraham's Avatar
Date registered: Oct 2006
Vehicle: '72 350SL, '85 300D, '98 E320, '14 GLK250
Quoted: 8 Post(s)
Injectors for M117
My 1972 350SL 4.5L has blue injectors.
Manual says these could be:
0 280 150 015 - Injection valves without protective sleeve
0 280 150 024 - Injection valves with protective sleeve
0 280 150 036 - Injection valves with protective sleeve & double sealing ring
Protective sleeve is 000 987 19 45 (Don't know if I have these or not)
Injectors for M116 engine appear to have similar specs (380cc/min 37.3 lb/min, 76HP, Tested at 300 Kpa), but they are color coded Yellow. Ending numbers are 013, 022 & 034. Sleeve is 000 987 18 45.
Finally to my question :- Is it possible to use the M116 injectors in a M117 engine? If so, which protective sleeve would I use? I would like to buy a set of injectors as spares and there is a set of yellows available.
Anyone know what the difference IS between the yellow and blue?
1972 350SL 4.5L - MBGraham, near Kingston, Ontario
MBGraham is online now
post #2 of 4 (permalink) Old 07-04-2008, 09:35 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 737 Post(s)
No, the injectors are not interchangeable. FYI, we offer reman 4.5 injectors for $49 each ($15 core).
GeeS is offline
post #3 of 4 (permalink) Old 07-04-2008, 09:39 PM Thread Starter
MBGraham's Avatar
Quoted: 8 Post(s)
OK Thanks - This will be a fall job. Probably will test existing ones first.
post #4 of 4 (permalink) Old 07-05-2008, 11:42 AM Thread Starter
MBGraham's Avatar
Quoted: 8 Post(s)
For anyone with an M116 engine, these injectors on eBay seem like a reasonable buy. See auction 250265395377. Wish they would fit my car, but it seems capacity is too low for 4.5L M117.
M117 4.5 --Anyone Have a Use For One? colinmi For Sale/Wanted/Trade/Giveaway 2 02-21-2008 06:45 AM
m117 rebuild? FLYNAVY W126 S,SE,SEC,SEL,SD,SDL Class 38 10-20-2007 10:59 AM
5.0 or 5.6 M117 into 280 SE? Dre@work W116 S, SE, SEL, SD Class 10 06-30-2007 11:45 AM
more m117 questions FLYNAVY W126 S,SE,SEC,SEL,SD,SDL Class 6 09-13-2006 02:23 PM
M117 Kingorcus W126 S,SE,SEC,SEL,SD,SDL Class 3 08-24-2005 05:39 PM
