1972 250c wont idle and have to keep foot on gas pedal? - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 06-26-2008, 09:33 PM Thread Starter
Date registered: Aug 2006
Vehicle: 1996 S600 Coupe
Quoted: 9 Post(s)
Hello My 250 c wont idle in park or in gear. I have to keep the foot on the gas or it will stall. The carburetors seem very responsive and work flawlessly other wise. Is there something that is supposed to keep the car running electronically on the carburetors? I have cleaned them with carb cleaner and still no help. If you stand on the passenger side and look at the carbs there is a white round plastic piece on each of them..my rear one has a burn mark on it. What are these and can I raise the idle on these? Thanks so much in advance. Nate
porshapower is offline
post #2 of 12 (permalink) Old 06-27-2008, 11:47 AM
Date registered: Jan 2007
Quoted: 85 Post(s)
One common problem is the idle solenoids. They are in the front of the carbs and have a pair of wires running to them. With the ignition on, unplug them and plug them back in. You should hear a click each time. If you don't, replace as needed.
Chuck Taylor
Falls Church VA
1998 SL500
1959 220S
1970 280SL
ctaylor738 is offline
post #3 of 12 (permalink) Old 06-30-2008, 11:33 PM
madmanmerc's Avatar
Vehicle: 1970 250c, 300e amg
Quoted: 17 Post(s)
i have had many problems with my carbs, including the problems you have. i sent them out and had them rebuilt by an old school merc mechanic. never had a problem after
jimmy
madmanmerc is offline
post #4 of 12 (permalink) Old 07-01-2008, 10:30 AM
Date registered: Jul 2008
Hi - Do you know where I can find these replacement idle solenoids? I can't seem to find them online.
Thanks
intact_radio is offline
post #5 of 12 (permalink) Old 07-02-2008, 08:33 AM
E-Class Owner's Avatar
Vehicle: 2003 Mercedes Benz E500
The moderator
of this forum, Ron at GermanStar comes to mind...
JR
E-Class Owner is offline
post #6 of 12 (permalink) Old 07-03-2008, 10:16 AM
thank you!
i meant to post that i managed to find the solenoids from weber directly. thanks for the hookup to germanstar though. that place looks like a gold mine.
post #7 of 12 (permalink) Old 07-04-2008, 06:00 AM
If you have problem with these things, don't try to resolve them on the net. Many people does that and it's not quite good. You can resolve your problem at the moment, but later? What if you'll have a bigger problem? My advise is to see a doctor. Not you of course. A car doctor.
grummyso is offline
post #8 of 12 (permalink) Old 07-08-2008, 10:43 AM
Quoted: 85 Post(s)
You should have told us that you have Webers! I assumed you had the original Zeniths.
Did the idle solenoids fix the problem?
Chuck Taylor
Falls Church VA
1998 SL500
1959 220S
1970 280SL
post #9 of 12 (permalink) Old 07-10-2008, 08:06 AM
I actually bought the car from porschapower, so there has been a small time-lag between his original post and my picking up on this thread.
Weber are sending them out (hopefully today), and I'll report back as soon as I have them in my grubby hands!
In other news, I've noticed white smoke from the exhaust and the oil pressure gauge is maxing out as soon as I turn the ignition. I fear that it's the head gasket, but the car hasn't been driven for some time and the fluids are old. Is there a chance at all that it might just be condensation in the oil tank and that flushing the fluids might fix the problem - or something equally easy to remedy? (I know that I'm not mechanically competent enough to attempt a head gasket fix sadly.)
post #10 of 12 (permalink) Old 07-11-2008, 03:31 PM
the idle solenoids arrived today and when i unpacked them they were different parts to that which i thought they were. nevertheless, i replaced them with the old ones and nothing happened. i then unplugged the wires from what i thought the idle solenoids were (the burned out looking, round white plastic things which are beside where the idle solenoid is) and plugged their wires into the idle solenoids and the car works fine.
my question now is, what did i unplug (and is it bad to have that unplugged), and where could the cables which should be running to the idle solenoids have disappeared to (or where should i run new ones from)?
    Car wont start without feet on the gas pedal gikn W126 S,SE,SEC,SEL,SD,SDL Class 5 03-21-2007 07:09 PM
    HELP, WHY's that? a-bout a 380 SLC, started, but off at idle if don't pedal gas Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 2 01-24-2007 03:02 AM
    Engine stops when the foot is off the gas pedal irshadwahab General Mercedes-Benz 6 11-30-2004 10:29 PM
    HELP, WHY's that? a-bout a 380 SLC, started, but off at idle if don't pedal gas Guest (MBNZ) R/C107 SL/SLC Class 3 09-24-2001 12:38 PM
    HELP, WHY's that? a-bout a 380 SLC, started, but off at idle if don't pedal gas Guest (MBNZ) Vintage Mercedes-Benz 2 09-19-2001 04:53 AM
