1971 250 Accelator Pump - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 06-22-2008, 05:53 PM Thread Starter
Amoosbenz's Avatar
Date registered: Jun 2008
Vehicle: 1971 250 1988 420SEL
Hey Guys
I have a 1971 Mercedes Benz 250 I need to change the accelator pump on the carburator, where is the accelator pump located and what is the (Zienth) carburator number?
Thanks for everyones help!
1991 420sel
1971 250 4DR
Amoosbenz is offline
post #2 of 4 (permalink) Old 06-22-2008, 06:16 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 737 Post(s)
#163
GeeS is offline
post #3 of 4 (permalink) Old 06-22-2008, 06:25 PM Thread Starter
Amoosbenz's Avatar
Thank you!
post #4 of 4 (permalink) Old 06-23-2008, 07:23 AM
E-Class Owner's Avatar
Vehicle: 2003 Mercedes Benz E500
You might want...
also want to check out the accelerator pump injection nozzle in the throttle bore. These can plug up over time and produce a small "piddle" of fuel and not the steady stream required for enrichment on heavy acceleration. There is actually a tool for measuring the accelerator pump output at the nozzle, but I suspect one would be difficult to come by these days.
The part [nozzle] in question is #190 in the breakdown drawing above. Be careful changing this piece, if necessary, as dropping it down the bore will necessitate a rather time consuming process to remove it...
Good luck,
JR
E-Class Owner is offline
FS: 1971 Mercedes 250 M_Co_87 For Sale/Wanted/Trade/Giveaway 6 12-14-2008 07:56 PM
Replacing water pump on a 1972 250 coollyle Vintage Mercedes-Benz 1 12-16-2005 07:41 AM
C220, the accelator problem Guest (MBNZ) W202 C-Class 6 01-19-2005 12:06 AM
Where is the other 114 group , list.. ? 1971 250 c Guest (MBNZ) General Mercedes-Benz 2 01-09-2002 02:03 PM
mercedes benz 1971 250 c Guest (MBNZ) General Mercedes-Benz 1 12-26-2001 07:44 PM
