240D high idle - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-11-2008, 11:05 PM Thread Starter
Date registered: Jun 2008
240D high idle
I am still working on the kinks my 1975 240D has. The biggest problem left is a high idle. It is managable, but still annoying. It is not very bad when the engine is cold, but it is very noticable once it warms up (gotta keep a little pressure on the brake when stopped to keep it from going). I checked out the little idle adjust knob, and it is set fine. The throttle linkage all seems fine as far as I can tell. The linkage to the injection pump seems to be all the way down with the accelerator not pressed. So what else could this be? I have not yet adjusted the valves or injection pump timing nor have I replaced the fuel filters yet. Could it also be some adjustment needed for the air intake?
bagawk is offline
post #2 of 3 (permalink) Old 06-13-2008, 11:38 PM Thread Starter
Anyone have any ideas or possible troubleshooting suggestions? Does the injection pump have any adjustments? The car also has a fair amount of blowby gases. Could this cause some of the problem? Could that be helped with a valve adjustment?
Anything would be great!
bagawk is offline
post #3 of 3 (permalink) Old 09-29-2009, 11:07 AM
Keevo114's Avatar
Try leaking out some OIL could be bruning the engine OIL instead of the pump. also try pushing the fuel cut off lever in a little see if it drops some. if so, there is also an adjustment on the back of the IP, but before you do that make sure the lines coming from the intake flap, going to the governor, is not leaking, Mine does the same if i disconnect it. If it's not leaking then remove the governor , and check the diaphram and spring inside for any holes or damage. be carefull its made of Leather, also the diaphrams rod connecting to the IP internal fuel rail is held by a saftey pin, you need to be very carefull use a magnet below it and a pair of small needle nose pliers to remove it, then the houseing should come off. Once out. you can clean the diaphram with a rag, don't use any chemicals or WD 40 or anything liek that here. And. once the you have checked the spring inside the throttle lever. clean that with diesel and dry with non-lent producing ragg. NOT shop towels or paper towels. If the gasket broke when taking apart do you best to either replace it, OR make one from gasket material. DO not use any silicone around here, it will fall off inside and get into the pump and destroy it. also be very carefull not to allow any debris get into the openings. If you still have problems. you can take it off again, and remove the rear support for the IP to the block, then you can access the 19mm nut and flat head locking screw. I belive out allows more fuel, but this is usually for top exccel fuel delivery, so if you back it out you may get more smoke, but more power.
Keevo114 is offline
    Testing Idle Valve - High Idle Problem Jonathan Laws W126 S,SE,SEC,SEL,SD,SDL Class 16 08-11-2012 05:55 AM
    High neutral idle + once in gear way rough idle Rickysa R/C107 SL/SLC Class 3 04-12-2008 12:50 PM
    Help! Normal idle when Cold/ High idle when Hot VicsBenz W201 190-Class 20 03-23-2007 08:58 PM
    Rough idle Vs high idle NewMBie W126 S,SE,SEC,SEL,SD,SDL Class 3 12-29-2004 09:17 PM
    High Idle Again. Big D W126 S,SE,SEC,SEL,SD,SDL Class 6 06-12-2004 01:49 AM
