the 450 valve adjustment - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 06-11-2008, 10:46 PM Thread Starter
Blu-spot's Avatar
Date registered: Nov 2006
Vehicle: 1972 280SE 4.5
Send a message via Yahoo to Blu-spot
Before i remove the cam covers, I just wanted to know if I need to have that special crowfoot to adjust the valves? I heard about them regarding diesel models, but mine's a m117, the car is a 72 280SE 4.5.
Steelies with caps and sealed beams RULE!!
Blu-spot is offline
post #2 of 2 (permalink) Old 06-18-2008, 11:38 AM
Date registered: Jan 2007
Quoted: 85 Post(s)
You for sure need a crowfoot, at least a standard one. If the adjusters are stuck, you will need the special tool. The adjusters are soft metal and easy to round. If you have a valve spring compressor, you can remove the rocker arm and get a socket on the really tough ones. I have had some that were so hard to move that I needed a breaker bar with an 18" piece of pipe for leverage.
Chuck Taylor
Falls Church VA
1998 SL500
1959 220S
1970 280SL
ctaylor738 is offline
    Valve Adjustment jjovero25 W123 E,CE,D,CD,TD,TE Class 32 07-05-2013 01:20 PM
    450 SL Valve adjustment frank220-450 Vintage Mercedes-Benz 3 07-14-2007 09:15 AM
    On valve adjustment... yonael W123 E,CE,D,CD,TD,TE Class 3 02-28-2007 07:33 AM
    First valve adjustment... Mattiesbenz W123 E,CE,D,CD,TD,TE Class 11 04-27-2006 05:24 PM
    Valve Adjustment NovaScotia300TD W123 E,CE,D,CD,TD,TE Class 21 12-18-2005 09:47 AM
