Rear axle noise left rear - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 06-05-2008, 06:07 AM Thread Starter
Date registered: Jun 2008
I have a 1973 Mercedes 450SLC that has a light scuffing sound when making left turns coming from the left rear . If I accelerate while turning left I get a horrible grinding /grating sound from the left rear side . How do I check the axles on this vehicle ,Any ideas on what I should be looking for will be greatly appreciated
jls368 is offline
post #2 of 2 (permalink) Old 06-05-2008, 06:42 AM
E-Class Owner's Avatar
Vehicle: 2003 Mercedes Benz E500
Sounds like...
you have a wheel bearing or homo-kinetic joint issue going on. Get the car on a lift and inspect the hub and half-shafts for bearing/seal and/or joint boot failure.
I would suggest that you refrain from driving the vehicle until you get the matter checked out.
E-Class Owner is online now
    Rear half axle noise 108Benz W123 E,CE,D,CD,TD,TE Class 12 04-12-2007 09:49 AM
    Light Grinding noise from rear axle!!!!!! sonped G-Class 1 02-08-2007 07:57 PM
    Play In Left Rear Axle Prochambers W126 S,SE,SEC,SEL,SD,SDL Class 0 03-08-2005 04:55 AM
    Rear differential/axle ‘clunk’ noise. CHDFW W201 190-Class 10 01-21-2005 07:56 AM
    noise at rear wheel/rear axle lietuviai W123 E,CE,D,CD,TD,TE Class 8 10-09-2004 12:34 PM
