4.5 fuel mixture - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 05-13-2008, 09:00 AM Thread Starter
Date registered: May 2008
Vehicle: 1972 280 se 4.5
4.5 fuel mixture
anybody know how i can improve air/fuel mixture? im getting about 3 miles per gallon, and its killing my wallet!!
kayaker1 is offline
post #2 of 7 (permalink) Old 05-13-2008, 08:51 PM
wbain's Avatar
Date registered: Dec 2003
Check the cold start injector to make sure it's not leaking. Make sure the other 8 aren't stuck open either. There could be quite a load of crud in there. What is the condition of all the spark plugs?
Then do a search on 'djet' to see what others are doing. You can also check the service manuals on W116 index: Mercedes-Benz S-Class - 280S, 280SE, 280SEL, 300SD, 350SE, 350SEL, 450SE, 450SEL & 450SEL 6.9 on checking and adjusting.
wbain is offline
post #3 of 7 (permalink) Old 05-14-2008, 08:00 AM
E-Class Owner's Avatar
Vehicle: 2003 Mercedes Benz E500
You might want...
Add a can of "Seafoam" to 1/2 tank of gas and then run the car until the reserve light comes on, then refill as normal. You can find it at Kragen/Shucks, or AutoZone, etc.
Seafoam has quite a following over on the W210 forum and elsewhere. It will help get the "crud" out of the injectors and intake system.
Good luck,
E-Class Owner is online now
post #4 of 7 (permalink) Old 05-14-2008, 11:23 AM
Date registered: Jan 2007
Quoted: 82 Post(s)
These engines have air temp and coolant temp sensors. If the brain doesn't get the right resistance from these, it can go pig-rich.
Chuck Taylor
Falls Church VA
1998 SL500
1959 220S
1970 280SL
ctaylor738 is offline
post #5 of 7 (permalink) Old 05-15-2008, 10:36 AM Thread Starter
my manual says to check the pressure sensor and replace if needed. also pressure regulator and adjust or replace?? are these issues anyone has incurred?
kayaker1 is offline
post #6 of 7 (permalink) Old 05-15-2008, 05:51 PM
Date registered: Jun 2004
Quoted: 5 Post(s)
The "pressure sensor' is that device on the firewall that is connected with a hose to the engine and has a plug connecting to the loom. Get a second hand one from somewhere and just swap it over to make sure it's OK. it uses engine vacuum to determine the engines fuel requirement so that hose must also be OK.
But you cannot just guess your way through a Djet by swapping stuff over. there is a right way and wrong way to fix injection .
Start by tuning the ignition so it is PERFECT .
Replace the fuel filter with a new one. And any of the rubber hoses by the tank.
then do a pressure test on the engine. Average pressure at the cold start valve is 28PSI. More than that and the pressure regulator(s) has failed or the return line to the tank and in the tank has become blocked.
Theres lots more to check but that should get you on the way.
mercmad6.3 is offline
post #7 of 7 (permalink) Old 05-08-2010, 03:22 AM
Date registered: Feb 2010
The seafoam website also talks about putting it straight into the crank case and PCV....anyone try that? I'm tempted to give it a shot from what I've read on other forums.
Former MB: "Miss Juliana" - 1972 280SEL 4.5
Current MB: 2013 C250
HBguy is offline
    Fuel Mixture Adjustment GHM W124 E,CE,D,TD Class 456 07-11-2016 01:00 PM
    Fuel Mixture Adjustment RickASolis W126 S,SE,SEC,SEL,SD,SDL Class 1 09-27-2007 07:33 PM
    How far off 50% can you adjust the fuel mixture? russ g W124 E,CE,D,TD Class 2 07-10-2007 11:12 AM
    2.5-16 Fuel mixture CO level Paul E W201 190-Class 0 07-01-2007 08:20 PM
    Fuel Mixture Dave G. G-Class 14 04-10-2001 10:29 AM
