» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > Vintage Mercedes-Benz
Old 05-12-2008, 07:10 PM   #1 (permalink)
Date registered: May 2008
'75 240 AC removal ?
Don't need/want the AC in my "75 240D and am curious if there are any potential issues, vacuum loss etc if it is taken out.
I'd like to remove the compressor and condensor but avoid fishing all the lines out.
Thanks I hope
David
911s55 is offline   Reply With Quote
Old 05-13-2008, 08:00 AM   #2 (permalink)
E-Class Owner's Avatar
Vehicle: 1997 Mercedes Benz E420
One small question...
Why?
If the A/C is not running, the clutch on the compressor spins freely, so there is no loss of economy [and I DO note you are a diesel owner].
Granted, the car is not exactly a hot rod, with or without the A/C, but a subsequent buyer may want that feature, which may not necessarily add value, but will make the car more marketable.
Inquiring minds want to know...
JR
E-Class Owner is offline   Reply With Quote
Old 05-13-2008, 09:10 AM   #3 (permalink)
JR
If it helps you to answer my question or just ease your curiosity, I'm not concerned about subsequent buyers, the car is not for sale.
I live in Seattle, when it's nice I roll down the windows and enjoy. The front of the compressor pully rattles with belt attached or not and with AC on or off. That bugs me. Dragging around any unecessary weight and working around it for maintenance and repair also bugs me.
If removed it wouldn't be discarded anyway.
So back to my question, yes, no, do, don't?
Regards
David
Old 05-13-2008, 01:00 PM   #4 (permalink)
E=MBČ
GermanStar's Avatar
Vehicle: GermanStar.net
You can safely remove the compressor and condenser without impact on the rest of the vehicle.
German Star
GermanStar is offline   Reply With Quote
Old 05-13-2008, 02:56 PM   #5 (permalink)
What he said...
Additionally I would carefully plug the hoses so no debris or moisture can intrude into the other A/C components and also secure them so that no rattles, noise or damage can occur. That way, should you decide to re-install the A/C you will not be looking at replacing any extra parts.
I suspected that it also had something to do with the extra weight. I know that "diesel doods" march to the beat of a different drummer. I once sold a diesel wagon to a dyed-in-the-wool diesel guy, and his first comment was along the lines of removing the roof rack as doing so might get him an additional 1/2 MPG...
Good luck on the project.
JR
Old 05-13-2008, 03:03 PM   #6 (permalink)
Eirik 400 SE's Avatar
Date registered: Jan 2008
Vehicle: 1991 400 SE
You should be happy it's a diesel.. The diesel's have lower ratio on the rear axle, compared to the gasoline-cars.. (So I've heard..)
1991 W140 400 SE
1973 W115 200
Eirik 400 SE is offline   Reply With Quote
Old 05-13-2008, 03:42 PM   #7 (permalink)
Thanks guys!
I'm in the middle of other under hood issues and thought about this, not really a MPG issue, I drive about 3 miles to the train and hop on it to work.
It's basically my urban tractor.
As far as the lower ratio, it was also built in the era of the nationwide 55mph limit so it doesn't care for too much above 60, but 1st gear is a stump puller.
Regards
David
Old 05-16-2008, 05:44 AM   #8 (permalink)
Magnetoz's Avatar
Date registered: Aug 2007
Vehicle: 1973 280SE 4.5L, 1974 240D, 1984 300D Turbo
My compressor was removed years ago. Still running strong.
Magnetoz is offline   Reply With Quote
1976 240 d glow indicator removal allgoodian Vintage Mercedes-Benz 0 04-30-2008 04:07 PM
E 240 1999 heated switch removal? Qamar W210 E-Class 0 01-15-2007 11:19 AM
Transmission Removal 1988 300TE/E W124 - Tips on removal, replacing shaft seals, etc. GermanCarNut W124 E,CE,D,TD Class 0 11-20-2006 02:15 PM
cab removal/ head removal/ hydraulic install/ esde Unimog 12 11-08-2006 05:21 AM
headrest removal on '82 240 D xaul General Mercedes-Benz 2 10-24-2006 06:10 PM
