» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > Vintage Mercedes-Benz
Old 05-10-2008, 06:55 PM   #1 (permalink)
SIC
SIC's Avatar
Date registered: Mar 2007
Vehicle: 1998 C230
Things to look for on 1968 280S
Hi everyone,
I'm looking at a 1968 280S with 150k miles on it tomorrow. Are there any model specific things I should look for on this car that would raise a red flag?
Thanks!
SIC is offline   Reply With Quote
Old 05-11-2008, 02:06 AM   #2 (permalink)
Date registered: Dec 2003
Vehicle: 1989 300SE, 1989 420SEL, 1965 220S, 2002 Ford Crown Vic Police Interceptor
Rust would be a problem, behind the wheels. Also, lack of proper front, rear and driveshaft greasing. The suspension wears out w/o grease.
Near Manassas Va. '89 300SE, 2002 Ford Crown Victoria Police Interceptor, 89 420SEL
Had '65 220SE, 67 230S, 72 280SE 4.5 Dad had '65 300SE LWB, '65 220SE
"Of all tyrannies, a tyranny sincerely exercised for the good of its victims may be the most oppressive." C.S. Lewis
wbain is offline   Reply With Quote
Old 05-11-2008, 07:07 AM   #3 (permalink)
Vehicle: 2000 ML320, 2005C240 4matic wagon, 1962 220SEb, 1979 300CD
Look for leak at hydro-pnumatic rear compensator or saging compensator spring.When rear wheels tilt in at the top / \ it is a dead giveaway. Also look at driveshaft flex discs and center bearings would be a good idea.
yaki b is offline   Reply With Quote
Old 05-11-2008, 09:06 AM   #4 (permalink)
E-Class Owner's Avatar
Vehicle: 1997 Mercedes Benz E420
Service records...
are a plus. You should have the engine checked out. The rings tend to go at around that mileage, especially the oil control rings. When the engine is warm, open the oil filler cap and listen for the sounds of excessive "blow by" and look for excessive oil vapor coming out of the opening.
Pull the dipstick for the transmission, if fitted with an automatic, and check the condition of the ATF.
Or better yet, if you are not familiar with these cars, have a qualified shop/tech check the car out for you; it will be money well spent, as these cars can be pricey to put right...
Good luck,
JR
E-Class Owner is online now   Reply With Quote
Best things / Worst things about where you live kvining Off-Topic 50 07-12-2007 09:24 PM
1968 280S/E BILLSONG Vintage Mercedes-Benz 15 11-06-2005 12:56 PM
280s sedan 1968 dj_zen General Mercedes-Benz 0 11-04-2005 03:35 PM
280s sedan 1968 dj_zen Vintage Mercedes-Benz 0 11-04-2005 03:33 PM
1968 280S transmission??? Dondeparis Vintage Mercedes-Benz 0 11-26-2004 10:36 PM
