230SL trunk latch - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 04-30-2008, 10:51 PM Thread Starter
Date registered: Apr 2008
230SL trunk latch
I am locked out of my trunk. The trunk latch on my 65 230SL failed to "pop" back out at last use. The key inserts but turns only 2/3's of the normal rotation and the latch won't open. Anyone know how to get me into my trunk. I think I'm destine to have the lock drilled out. Any advise?
TWEngel is offline
post #2 of 3 (permalink) Old 05-01-2008, 03:06 AM
wbain's Avatar
Date registered: Dec 2003
Ask these guys:
Pagoda SL Forums
wbain is offline
post #3 of 3 (permalink) Old 05-20-2008, 06:20 PM
Date registered: May 2008
trunk lock
Hey you can usually drill a small hole on the left side under the molding and push the latch. I have done this on 108 s and a 113 s. you remove the single screw holding the molding (by the lic light ) and wigle pry (with care)the molding out from under the lock and off the taillight. at this piont drill a 6mm hole ( that will be covered by the molding ) and push striker,the lock in. after it is open three phillips removes the striker and 2, 9mm nuts hold the lock assembly. good luck
heinauto is offline
    Trunk latch stuck Jennifer Shea C208/A208 CLK-Class 8 11-23-2010 11:30 AM
    pin out for trunk latch kennyd W203 C-Class 0 03-31-2008 10:27 PM
    ML320 trunk latch mamalana W163 M-Class 0 06-20-2007 04:41 PM
    Trunk lid latch StuttgartStud R170 SLK-Class 7 10-12-2004 01:47 PM
    Trunk Latch Xylocaine W163 M-Class 2 07-21-2003 07:28 AM
