» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > Vintage Mercedes-Benz
Old 04-26-2008, 10:03 AM   #1 (permalink)
Date registered: Mar 2008
Vehicle: 1971 250C
Carb compatability?
Hello, I'm looking at a set of Zenith carbs with manifolds on ebay. They are off of a 1967 250S. Are they compatible with my 1971 250C? If they are please don't out bid me. (LOL) I really need some Zenith parts to get my car on the road.
Thanks, Joe
jccal22 is offline   Reply With Quote
Old 04-26-2008, 02:10 PM   #2 (permalink)
E-Class Owner's Avatar
Vehicle: 1997 Mercedes Benz E420
The 250S...
is a 2.5 litre displacement, and your 250C is a 2.8 litre, M130.
The jetting will be a bit off [lean], but you should be okay... You will most likely have to work over the new carbs, so be sure to check the top plate, which can be warped by ham-handed mechanics over-tightening the air cleaner assembly... If worst comes to worst, you can always swap your jets over from the old carbs.
Good luck,
JR
E-Class Owner is offline   Reply With Quote
Old 04-26-2008, 02:32 PM   #3 (permalink)
Vehicle: 1971 250C
External parts
I'm not planning on swapping the whole carbs. I'm mainly concerned with some external parts such as the fuel return valve and the vacuum plunger that kicks the idle up under load. Do you know if these are the same?
Thanks, Joe
Old 04-26-2008, 03:09 PM   #4 (permalink)
As I recall,
the fuel return value should be the same. The "dash-pot," [which is the part you are referring to] judging from the picture in the eBay listing, does not look any too good, the spring loaded shaft appears bent. Most dash-pots are non-operational on old cars anyway... the diaphragms eventually leak.
The top plates are slightly different then yours, the link for the choke butterfly on the older carbs is out in the open, and enclosed on the later ones.
If you are buying the carbs for parts, then go for it. The cost of individual OE replacement parts on these is horrendous. When I had a 250/8 and a 250C, I kept a couple of sets of these carbs just to "cannibalize"...
Good luck,
JR
Old 04-26-2008, 03:21 PM   #5 (permalink)
Vehicle: 1971 250C
Thanks, I'll put in a bid and see what happens. I'm not going to high though.
Joe
parts compatability urchin Unimog 3 09-11-2006 03:42 PM
tranny compatability psycodragon W123 E,CE,D,CD,TD,TE Class 6 01-05-2006 06:11 PM
GLASS COMPATABILITY AMSOIL300CDT W123 E,CE,D,CD,TD,TE Class 0 04-02-2005 07:36 AM
Seat Compatability dlg1968 General Mercedes-Benz 0 03-04-2004 07:55 AM
Part Compatability Guest (MBNZ) W124 E,CE,D,TD Class 1 05-17-2001 04:52 AM
