» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > Vintage Mercedes-Benz
Old 04-24-2008, 08:15 AM   #1 (permalink)
Oskar
Date registered: Oct 2006
W108 - Cruise Control
Hi folks,
I would like to have cruise control in my W108. Anyone already done this using parts from a W107/114 or so ?
What body would be best to get the parts from ?
Thx
Oskar
Oskar is offline   Reply With Quote
Old 04-24-2008, 09:51 AM   #2 (permalink)
E-Class Owner
E-Class Owner's Avatar
Vehicle: 1997 Mercedes Benz E420
Most...
cruise control installations on 108/109 chassis are "aftermarket" units. You did not mention if the vehicle is an "S" or an "SE/L" as that does impact the physical installation.
JR
E-Class Owner is offline   Reply With Quote
Old 04-25-2008, 09:50 AM   #3 (permalink)
Oskar
JR
its a 280SE 4.5.
I would like to stay as close as possible to 'factory look and feel'. Thats why I am considering to pull the parts from another MB chassis
The tempomat switch (A0045458724) from a 114 chassis should fit to the column, I hope
Oskar
Old 04-26-2008, 12:58 AM   #4 (permalink)
mercmad6.3
Date registered: Jun 2004
if you can find the original W116 cruise ( 350SE), that will almost bolt on to your engine and fit the car with little hassle .It's actually a Ford device with seperate switch ,it didn't have the column switch.
The later cruise( W116-W107 etc ) needs a speedo feed so if you want to use one of those you will need to use the speedo from a W114 with the tempomat connection. ( rare...)
Believe me,unless you have a week or two to strip old wiring looms and solder stuff together ,you may want to consider an after market unit.
mercmad6.3 is offline   Reply With Quote
Old 04-27-2008, 10:56 AM   #5 (permalink)
Oskar
well, I have a W114 parts car here and that one has the ford device.
So, thats probably the easiest route
I do not think that was original, the way it is fit in looks like quick n dirty. I actually did not expect a Ford unit in a MB :-). Live and learn ....
New W108 Owner...Source for W108 Door and Window Seals? LaterApex Vintage Mercedes-Benz 5 03-24-2008 12:51 PM
Climate Control Levers W108 John-Glen Vintage Mercedes-Benz 4 08-19-2006 06:34 PM
Cruise control display question. Does you car display the cruise control speed in the lower display? aquascape R171 SLK Class 42 01-15-2006 01:37 PM
cruise control vs. climate control CCarlisle W123 E,CE,D,CD,TD,TE Class 0 11-04-2005 09:51 PM
Fitting Cruise control to a non-cruise car - Is it possible? ScrapingScrap W126 S,SE,SEC,SEL,SD,SDL Class 2 08-08-2004 09:34 AM
