W115 floorshift, conversion to Power steering - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 04-20-2008, 02:23 AM Thread Starter
Eirik 400 SE's Avatar
Date registered: Jan 2008
Vehicle: 1973 W115 200 /8
Hi.
I've just bought a 1971 /8 200. (W115) Wich basicly has no equipment at all.
I would like to put in Power-steering.
I have the pump, the reservoir, the hoses and the steeringgear itself.
BUT, the guy I bought it from said"You have to shorten your steeringshaft.. Aprox 10mm or so, to make the gear fit.
Also, I saw that some web-shop had the little link that goes between the steering gear and the steeringshaft for sale.. And it looked shorter than the original link..
Does anybody know if I need to shorten the steering-shaft ?
Or can I just buy one of those links ?
I could also get my hands on another steeringshaft, and thus keep the original for later use..
1991 W140 400 SE - SOLD !!
1973 W115 200 -For sale as project.
Eirik 400 SE is offline
post #2 of 4 (permalink) Old 04-20-2008, 09:57 PM
wbain's Avatar
Date registered: Dec 2003
Quoted: 4 Post(s)
Have you tried to mount the new steering gear? You could also check with the classic center about part numbers or use the EPC to check it yourself.
If you do replace the steering gear, make sure you use new bolts to mount the steering gear.
wbain is offline
post #3 of 4 (permalink) Old 04-21-2008, 06:37 AM
E-Class Owner's Avatar
Vehicle: 2003 Mercedes Benz E500
Also...
when you pull the original steering box, check around the mounting holes for cracking of the inner fender panels.
The W114-115 chassis is known for this, and there is a modification kit available which contains a heavy reinforcing place and new, longer bolts. The reinforcement is actually MiG-welded to the frame and helps to take some of the strain off of the chassis sheet metal/frame rails.
Good luck on the project.
JR
E-Class Owner is offline
post #4 of 4 (permalink) Old 04-21-2008, 01:35 PM Thread Starter
Thank's ..
Wasn't aware of the reinforcement kit.. Have to check the EPC later for that..
I will of course check everything when I dismantle and assemble things..
Power steering box and power steering pump thoth_9 W123 E,CE,D,CD,TD,TE Class 7 09-15-2009 07:51 PM
Power memory seat conversion ???? gw17625410 W163 M-Class 0 01-28-2008 07:51 AM
107 power top conversion? sportscartiki R/C107 SL/SLC Class 4 02-10-2007 09:27 PM
Sorry.. W115 steering column question anilv Vintage Mercedes-Benz 2 10-25-2005 06:18 AM
Power mirror conversion SHIFT_diesel W124 E,CE,D,TD Class 3 06-29-2003 09:12 AM
