door latch is broken - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 04-18-2008, 02:26 AM Thread Starter
SeaSchow's Avatar
Date registered: Apr 2008
I have a 1976 300D. the driver's side door latch is broken. Can I repair
without removing the door panel? Where can I find this repair information.
Thanks,
Joe
SeaSchow is offline
post #2 of 2 (permalink) Old 04-18-2008, 06:39 AM
E-Class Owner's Avatar
Vehicle: 2003 Mercedes Benz E500
W115 Chasis, right?
The door panel has to come off... there are linkages attached to the latch mechanism.
Steps: 1) Unscrew the "Golf Tee" locking/unlocking pull, 2) pull up on the interior cap piece to remove, 3) gently pry out the black insert in the latch release lever, 4) unscrew the chrome surround and remove, 5) remove the 2 screws in the hand rest and remove the rest [the aluminium trim pieces may drop off, so keep an eye out for this], 6) remove the trim piece around the latch at the edge of the door, and 7) gently pry around the edge of the door panel with a non-marring tool, to pop the panel loose.
The latch mechanism will have 2 linkages connected by clips, these swing away from the rod and come off. You are now ready to remove the latch mechanism.
Usually these are just replaced. Reinstallation of the pieces is in reverse order, as DB is fond of saying.
Good luck!
JR
E-Class Owner is offline
Broken hood latch cable AG-wagen G-Class 17 05-30-2012 01:24 PM
Messed up door latch Va170_Bill R170 SLK-Class 11 06-15-2009 04:14 PM
door latch broken spring? andrew_falky W126 S,SE,SEC,SEL,SD,SDL Class 10 08-21-2007 03:58 PM
Fix for broken glovebox latch 86 420sel IceBlue_1980_300TD W126 S,SE,SEC,SEL,SD,SDL Class 0 03-01-2007 11:28 AM
Hood latch interior...Help Broken... pachanga R170 SLK-Class 0 01-29-2006 06:50 PM
