white smoke - Mercedes-Benz Forum
post #1 of 23 (permalink) Old 04-08-2008, 11:20 AM Thread Starter
madmanmerc's Avatar
Vehicle: 1970 250c, 300e amg
Quoted: 17 Post(s)
white smoke
i changed my head gasket and also had my head refaced, but i still have white smoke coming from exhaust. as the the car warms up it becomes alot of smoke. any ideas. thank you
madmanmerc is offline
post #2 of 23 (permalink) Old 04-08-2008, 12:35 PM
E-Class Owner's Avatar
Vehicle: 2003 Mercedes Benz E500
Yep...
White smoke typically means coolant is getting into the combustion chamber(s)...
Did you have the head checked for cracks by an expert? Some cracks in the alloy casting can be almost invisible and open up as the engine reaches operating temperature.
Good luck,
JR
E-Class Owner is online now
post #3 of 23 (permalink) Old 04-08-2008, 01:18 PM
Eirik 400 SE's Avatar
Date registered: Jan 2008
Vehicle: 1973 W115 200 /8
Could be a crack in the head or in the engineblock itself.
Dismantle and get someone to check the head for cracks with some pentrating fluid and some developer-spray..
1991 W140 400 SE - SOLD !!
1973 W115 200 -For sale as project.
Eirik 400 SE is offline
post #4 of 23 (permalink) Old 04-08-2008, 04:15 PM Thread Starter
madmanmerc's Avatar
Quoted: 17 Post(s)
the head was repaired by a reputable shop. they checked it for cracks and even repaired a coroded area with some welding.
post #5 of 23 (permalink) Old 04-09-2008, 09:15 AM
Then it's the block itself or the gasket that need to be checked..
You could maybe try to get someone to check the exhaust ? Toi see if if really is vapour that comes out..
post #6 of 23 (permalink) Old 04-09-2008, 10:05 AM
I have not seen a...
M110 block for a very long time, but if it is similar to the late M130 block, there were "slots" cut into the block between the cylinders; these slots were between the holes that allowed for coolant to pass from the water jacket in the block up into the head.
These slots [if present] were a problem, as due to the thin cylinder walls, there was very little "meat" for the head gasket to seal against.
The shop that I was affiliated with would fill the slot with an epoxy resin, trim the resin flush, and clean the water passage holes; this would allow the head gasket a little more contact area for a better seal.
Good luck with your problem,
JR
post #7 of 23 (permalink) Old 04-14-2008, 10:40 PM Thread Starter
madmanmerc's Avatar
Quoted: 17 Post(s)
i was wondering. could it be water and coolant in the exhaust. i have only turned on the car once since changing the head, and it ran for about 15 minutes. should i let it run longer before taking the motor apart. someone told me it should run at least an hour. any help would be appreciated. thanks
post #8 of 23 (permalink) Old 04-15-2008, 07:42 AM
Could be...
If you are going to run the car enough to make sure exhaust is free from old coolant and condensation, I would recommend that you monitor the engine during the entire time you are doing this, i.e., do not start her up and just walk away...
JR
post #9 of 23 (permalink) Old 04-15-2008, 10:20 AM
After a partial rebuild, the engine should run for 2hours+ preferably while driving.. So it's not the same rpm all the time..
post #10 of 23 (permalink) Old 04-16-2008, 09:43 PM Thread Starter
madmanmerc's Avatar
Quoted: 17 Post(s)
i will watch her while she is running. so you say 2 hours should do it
    White Smoke bloodpirate W124 E,CE,D,TD Class 10 08-04-2009 12:11 AM
    white smoke Al W210 E50 AMG, E55 AMG 6 05-10-2007 04:58 PM
    White Smoke SParkyMerc W126 S,SE,SEC,SEL,SD,SDL Class 2 05-12-2006 01:10 AM
    the white smoke Stefaan@be G-Class 16 12-01-2005 01:22 PM
    White Smoke malibuite R171 SLK-Class 9 05-03-2005 04:57 PM
