» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > Vintage Mercedes-Benz
Old 04-06-2008, 09:49 AM   #1 (permalink)
verdejor
verdejor's Avatar
Date registered: Aug 2005
Vehicle: 1976 W116, 450SE --- 1981 W126, 380 SEL
How to convert shifter
I have a column shift car. I am considering changing the tranny. How can I convert the Floor shift transmission to match to the column shifter?
not interested in changing the column to a floor shifter. I like the look and available space.
It's not all that, But it's mine.
verdejor is offline   Reply With Quote
Old 04-06-2008, 12:38 PM   #2 (permalink)
E-Class Owner
E-Class Owner's Avatar
Vehicle: 1997 Mercedes Benz E420
It would be helpful...
if you told us what year and model/chassis you are talking about...
Automatic of manual transmission? These kind of details matter a great deal in formulating a proper response.
Thanks,
JR
E-Class Owner is offline   Reply With Quote
Old 04-08-2008, 09:04 AM   #3 (permalink)
verdejor
verdejor's Avatar
1972 Mercedes 280SEL. Automatic Column Shift
want to replace current tranny to one I have but the one in car is column shifter and the replacement is a floor shift one.
sorry, didnt quite think it was such a factor. wanted to get a general idea before tackling the job/fabricating if needed.
thanks for the prompt reply.
Old 04-08-2008, 12:49 PM   #4 (permalink)
E-Class Owner
As I recall,
the differences are in the linkages and connecting pieces, not in the transmissions themselves. MB didn't make one transmission housing for column shift cars and a different housing for floor shift cars.
Your new transmission can be modified to accept the mechanical input from the column shifter. That would be the easiest way to go; however, if you like the aesthetics of the console shifter, you are going to be replacing a bunch of parts, including the steering column shroud and center console piece...
Good luck,
JR
Old 04-09-2008, 05:11 AM   #5 (permalink)
verdejor
verdejor's Avatar
thanks. I think that quite answers the question... But no, I will not be changing my console. I am leaving the column shift operable. DO NOT want a floor shift, which was my concern sincei nstalling the new tranny like it is would require me making a hole to the floor and changing my console.
Old 04-09-2008, 09:10 AM   #6 (permalink)
E-Class Owner
Sounds like...
you are good to go. Are you doing the tranny swap yourself, or having it done at a shop?
As I recall, book time is around 6 hours, but a good tech can do it in 3-4.
Good luck,
JR
Old 04-24-2008, 03:11 AM   #7 (permalink)
verdejor
verdejor's Avatar
thx. I will be doing everything myself (like always) lol. I learn the hard way sometimes, but I get it done! lol
yeah the car has a stock column shift with matchin tranny
the replacement tranny(floor shift) will be converted for column shift.
POSSIBLY throw in a 302 Ford engine, but that's just all talk for now...
Old 04-26-2008, 01:16 AM   #8 (permalink)
mercmad6.3
Date registered: Jun 2004
There is only ONE difference,the hole on the shifter arm on the side of the trans. On a floor shift car it's on the forward most hole. On a column shift car the shifter arm has a bolt on extension that lowers the link from the firewall to position closer to the oil pan.
Everything else is the same,column or floor shift.
BTW, a Ford Windsor is a drop in fit,a far better idea than the more common Chev swap which wont clear the steering drag link.
mercmad6.3 is offline   Reply With Quote
Old 05-02-2008, 06:31 PM   #9 (permalink)
verdejor
verdejor's Avatar
Need Online manual - Fuel Pump install
1972 280SE
Need a diagram and even better the link for the online manual for the fuel Pump installation.
Bought this car but the pump and filter were removed and need to ensure it is installed correctly.
thanks!
Old 05-02-2008, 09:18 PM   #10 (permalink)
wbain
Date registered: Dec 2003
Vehicle: 1989 300SE, 1989 420SEL, 1965 220S, 2002 Ford Crown Vic Police Interceptor
This should get you started:
http://www.detali.ru/cat/oem_mb2.asp...SGR=001&SGN=01
BTW, we also need to know if it's a 6 or an 8.
What are you changing the trans to and why?
Fuel Pump Link
We're not mind readers despite what our wives think.
Near Manassas Va. '89 300SE, 2002 Ford Crown Victoria Police Interceptor, 89 420SEL
Had '65 220SE, 67 230S, 72 280SE 4.5 Dad had '65 300SE LWB, '65 220SE
"Of all tyrannies, a tyranny sincerely exercised for the good of its victims may be the most oppressive." C.S. Lewis
wbain is offline   Reply With Quote
Another 124 convert alexnatt W124 E,CE,D,TD Class 9 08-25-2007 07:23 AM
Convert to islam now or else.. maine_coon Off-Topic 116 09-07-2006 04:45 PM
convert-- 2.3 into-- 2.3 16v wvh187 W201 190E, D-Class 7 08-19-2006 06:54 PM
How about this for a Benz convert... irvingst R170 SLK Class 0 09-23-2005 08:20 AM
'70 280SE Convert to 4.5 Guest (MBNZ) General Mercedes-Benz 2 03-27-2001 01:21 AM
