help---my car smokes like crazy!!! - Page 2 - Mercedes-Benz Forum
post #11 of 13 (permalink) Old 03-27-2008, 05:10 AM
Date registered: Jun 2004
Quoted: 5 Post(s)
Sounds like a broken piston/pistons. A M110 will still run almost Ok with a broken piston but will smoke as you describe.
mercmad6.3 is offline
post #12 of 13 (permalink) Old 03-30-2008, 11:23 PM
Date registered: Mar 2008
Vehicle: 75 450SLC W107
K&N filters are oil treated! The oil from the filter coats the inside of your intake system. This will foul up fuel sensors in the intake system!! Are you sure its oil smoke and not a fuel mixture problem caused by the Filter? You are losing an abnormal amount of oil right?
JJSMILHOUS is offline
post #13 of 13 (permalink) Old 03-31-2008, 07:21 AM
E-Class Owner's Avatar
Vehicle: 2003 Mercedes Benz E500
His engine...
has the CIS mechanical injection system, I believe, which should be significantly less sensitive to any stray oil from the K&N. JJSMILHOUS is correct that K&N filters are not good for the air mass sensors on the later EFI systems.
E-Class Owner is offline
    My car smokes crack mrmacp W210 E-Class 16 10-23-2006 12:16 PM
    crazy car trouble bshackelford711 W201 190-Class 9 09-22-2006 08:52 AM
    Is this car worth $350? It smokes bad!! turbosing777 W123 E,CE,D,CD,TD,TE Class 9 02-03-2005 09:54 PM
    Crazy new car DEATHERAGE R170 SLK-Class 7 09-08-2004 04:34 PM
    car creaks like crazy vinceching W140 S-Class 2 03-27-2004 02:59 AM
