W108 - idle/warm start problem - Page 2 - Mercedes-Benz Forum
post #11 of 13 (permalink) Old 03-30-2014, 11:06 AM
Date registered: Feb 2012
Vehicle: 2006 C230 Sprots V6, 1972 280 SEL 4.5
Originally Posted by Oskar View Post
well, as promised - here is the update
pulled out slide, checked it in hot water - closing at 70 deg C. - works
new fuel filter - fixed a leak in the return line as well
- problem still exists
replaced vacuum line from distributor via AC valve to throttle
- no change
replaced lower seals on the injectors
measured fuel pressure - too low just 1.2 bar instead of 2. adjusted fuel pressure. Pressure holds.
car is way too rich now. the adjuster for idle emission is on left(lowest) setting
Lambda reads .75 to 0.8 at 75 mph cruising ( I used a innovate LC1 at the tailpipe )
the manifold pressure sensor comes to my mind - replaced it with one from a parts car.
Bingo!
idle (air) adjust nice now, idle speed emission adjusts nice.
Lambda when accelerating is around 1. Even fuel cut off works ....
Engine is running now like a MB V8 should run
Thanks for all suggestions - got me on the right track
I bought the car as an restoration object, half a year ago. Seems to me someone tried to compensate running too rich by lowering the fuel pressure
Thx again
Oskar
Hi Oskar,
Would you happen to have a photo of your M117 engine? I'm trying to determine if my problem is the vacuum lines from throttle body to the distributor diaphragm. If all else fails I will consider replacing my MAP sensor. The photo of your engine will help me determine if I have my vacuum lines installed wrong. Thanks in advance
wfd1 is offline
post #12 of 13 (permalink) Old 03-31-2014, 07:51 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
common problem , when you shut the engine off hot , if you watch the temp gauge , after a few minutes , the temp goes higher in engine .since this efi system is temp controled , the temp sensor on top of intake manifold send a lean signal , so if the fuel mix is on the lean side to start with , you end up with a over lean condition .the fix is to set the mix richer , like 3 % HOT at 2500 rpm .if you unplug the air filter temp sensor [ to test ] , this will richen the mix , the engine should start up better .
agillot is offline
post #13 of 13 (permalink) Old 03-31-2014, 09:09 AM
Unfortunately for me, my engine is running rich. Way too rich that I just blew out my muffler. I definitely need to further adjust the air/fuel ratio to run leaner. Prior to blowing the muffler, my W108 was running extremely well. Aside from the slight fuel smell (from rich exhaust fumes), the engine was performing flawlessly with strong acceleration. As soon as I replace the muffler I'll work on the a/f mixture. Lucky for me I have access to a gas analyzer.
Thanks for the advice.
wfd1 is offline
Idle problem for W108 280SEL (3.5) from 1971....Please help ESOOO Vintage Mercedes-Benz 3 03-30-2008 01:07 PM
warm idle problem - basic help roverboy W124 E,CE,D,TD Class 0 02-28-2008 07:38 AM
two problems : humming at start up / rough idle until warm 90 w126 420 se W126 S,SE,SEC,SEL,SD,SDL Class 11 10-02-2007 06:50 PM
Warm start problem Peter Seow W126 S,SE,SEC,SEL,SD,SDL Class 2 05-20-2004 09:12 PM
warm start problem ianwatsoni G-Class 8 10-08-2003 09:31 AM
