Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > Vintage Mercedes-Benz
Old 03-23-2008, 09:09 AM   #1 (permalink)
BioDeezNuts's Avatar
Date registered: Mar 2008
Vehicle: 1975 Mercedes Benz 240D
Send a message via AIM to BioDeezNuts
Glow plugs only work occasionally, why?
The glow plugs in my 1975 240D only work when they want to. I replaced them one week ago and they worked great every time, but now its back to starting fluid. I dont like starting fluid, for I dont feel like adjusting the valves every week. Even though its nice to get intimate with the ole beast, I would rather find where the relay is for the plugs, and maybe test it and replace it. Anyone have any input for me? Any help would be surely appreciated. And if you are in my area, start using Bio! i will hook you up. I make quality fuel.
BioDeezNuts is offline   Reply With Quote
Old 03-23-2008, 09:16 AM   #2 (permalink)
Ericthenorse's Avatar
Date registered: Jan 2008
Vehicle: 1991 190e 2.3 auto
On my old VW rabbit diesel, I had problems because my ground to the chasis was bad. Just something you might check..... do the plugs on these things run through a relay??? find it and check it out..... Also, WD40 makes an excelent starting fluid for a diesel.....
The large print giveth,and the small print taketh away....
Ericthenorse is offline   Reply With Quote
Old 03-23-2008, 03:36 PM   #3 (permalink)
Merc600sec's Avatar
Date registered: Mar 2004
Vehicle: SEC 600 COUPE (RHD) One of the chosen few.
Send a message via MSN to Merc600sec Send a message via Yahoo to Merc600sec
throw the starting fluid away before you have to throw your engine in the bin.. what makes you think its the glowplugs ??
If you've GOT to have a extension,
Have a BIG one.
Torque isn't cheap
Merc600sec is offline   Reply With Quote
Old 03-24-2008, 06:08 AM   #4 (permalink)
Date registered: Jan 2004
Vehicle: 1959 220S cabriolet, 1983 240D original owner, 1999 E300 turbo diesel, 1988 560SL
When do they work - any pattern? Only when hot, only when cold? Does the glow plug light work as it should? Did you check the resistance, ohm reading, on the plugs? If you used Autolite plugs, they could already be bad.
Len
sokoloff is offline   Reply With Quote
Old 03-27-2008, 07:16 AM   #5 (permalink)
The Glow plugs have only worked once since I started having this problem. It happened for a while, I replaced them, then they worked for a week or two. Then nothing. There is no glow plug light, there is an actual glow plug in the dash that lights up red hot when they are hot. I have not touched the car for a while, but I will get a multitester and check the resistance. There is a relay, which I will check too, I just dont know where it is on the 115 body diesels. I will figure it out eventually, and will let everyone know. Thank you all for your replies, and if anyone else has any knowledge, lemme know! thanks!
Old 03-27-2008, 05:10 PM   #6 (permalink)
79Mercy's Avatar
Date registered: Oct 2006
Vehicle: 1979 280CE
Do not use starting fluid in a diesel
'79 280CE with 212,600 miles and still going strong!!
79Mercy is online now   Reply With Quote
Old 03-28-2008, 03:19 PM   #7 (permalink)
Magnetoz's Avatar
Date registered: Aug 2007
Vehicle: 1973 280SE 4.5L, 1974 240D, 1984 300D Turbo
The relay is under the dash on the left side of the steering column. Its an aluminum box.
Magnetoz is offline   Reply With Quote
Old 03-29-2008, 04:15 PM   #8 (permalink)
p_stampy's Avatar
Date registered: Aug 2005
Vehicle: '74 240D, N15 Pulsar
how would you use starting fluid on a diesel?
p_stampy is offline   Reply With Quote
DIY Glow plug relay and Glow plugs 240Dbio W123 E,CE,D,CD,TD,TE Class 11 01-16-2008 02:37 PM
Changed voltage regulator, now glow plugs dont work ladybee W126 S,SE,SEC,SEL,SD,SDL Class 3 08-15-2006 03:23 PM
Glow Plugs or Spark Plugs?? Are they the same thing? sudha W123 E,CE,D,CD,TD,TE Class 4 11-30-2005 10:27 PM
No glow in the glow plugs.... dieselpowered W126 S,SE,SEC,SEL,SD,SDL Class 7 09-11-2005 05:07 AM
Spark plugs, who's work best, and how about Platinum or Iridium plugs? Bruce R. W201 190E, D-Class 2 07-11-2003 04:25 AM
