Something weird with my 108 - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 03-22-2008, 01:46 PM Thread Starter
Date registered: Jun 2006
Vehicle: 2003 230 Kompressor, 1970 280SL, 1991 300SL, 1970 SEL Limo
Here's the scoop, I've got a 70, 280SEL, it runs great but has developed a weird issue. It started leaking not that long ago. After investigating the leak, I discovered that intake bellow (Hose between the throttle body and air canister) had a bunch of oil in it. The only place it could be coming from is from the crank case vent off of the valve cover. (As it is before the throttle body.)
I took off the beather hose and can't believe how much pressure actually comes from there. (Along with a bit of oily smoke)
Any ideas on why so much oil is coming out? Valve seals? Guides? Wouldn't either of these cause the car not to run well? As before, the car runs very well. (And doesn't smoke) I'm stumped.... any ideas?
Michael C is offline
post #2 of 4 (permalink) Old 03-22-2008, 04:00 PM
E-Class Owner's Avatar
Vehicle: 2003 Mercedes Benz E500
How many miles...
on the car/engine?
Sounds like "blow-by" and that means rings... which is not good news.
If it runs okay, and does not consume too much oil, just clean up the mess, switch to 20-50 [if you are not already using this weight] oil and drive it.
Eventually, you will have to do something, but in your locale there are no smog issues, so... it can wait.
E-Class Owner is offline
post #3 of 4 (permalink) Old 03-23-2008, 03:49 AM
sclassy's Avatar
Date registered: Mar 2008
Vehicle: Alfa Romeo 1750 GTV, BMW 2002, BMW 528it, R107 380SL, S202 C43T.
I had this same symptom on my 280SE, cleaned the mess up and after my first oil change the oil never seemed to come back. I had the car for over 18 months, and it never skipped a beat.
sclassy is offline
post #4 of 4 (permalink) Old 03-25-2008, 11:08 PM
Vehicle: 75 450SLC W107
In that rubber hose should be an oil wic ( screen) to keep oil from being pulled into the intake. If that is in place try changing the oil with 30wt. of the total qty needed substitute 1 quart with type A transmission fuild. You will need to change oil in a week cause this will scrub the motor!
JJSMILHOUS is offline
    my 108 Jackasic Vintage Mercedes-Benz 5 03-10-2006 05:28 AM
    108 Octane Chucky300 W220 S-Class 1 03-06-2006 05:30 AM
    108 tuning willholman Vintage Mercedes-Benz 5 10-19-2005 06:50 AM
    new headlights for the 108 Jackasic Vintage Mercedes-Benz 14 10-02-2005 08:59 PM
    280 SE W 108 buggy911 Vintage Mercedes-Benz 4 08-31-2005 05:24 PM
