1971 280 SEL Get Click No Start - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 03-19-2008, 07:53 PM Thread Starter
mrbaddog's Avatar
Date registered: Mar 2008
Unhappy 1971 280 SEL Get Click No Start
I have a 1971 280SEL parked it in 2001 in my garage. Charged battery and tried to start it, get one (1) 'click' and no start.
What is causing the click, external solenoid?? Click seems to come from driver side while starter is on passenger side.
I replaced battery but not sure if it is fully charged, will take it back and make sure, but still get the click - no start. Lights do not dim when I try, even with high beams.
Never any problem with starter before, garage unheated but dehumidified.
mrbaddog is offline
post #2 of 7 (permalink) Old 03-20-2008, 07:43 AM
E-Class Owner's Avatar
Vehicle: 2003 Mercedes Benz E500
Most likely...
the starter solenoid... You could try banging on it [not too hard BTW] and see if that frees it up. Bosh reman unit or a good local re-builder can get it going for you. R/R is not too tough on these older cars.
Good luck,
JR
E-Class Owner is offline
post #3 of 7 (permalink) Old 03-21-2008, 07:17 PM Thread Starter
mrbaddog's Avatar
Where is the starter solenoid?
Where is the starter solenoid and what does it look like. I do not believe it is physically on the starter.
mrbaddog is offline
post #4 of 7 (permalink) Old 04-07-2008, 09:12 PM Thread Starter
mrbaddog's Avatar
Found Problem
I found the wires going to the bendix on the starter were completely disintegrated. Apparently, there was a problem with the insulation on the wires and someone had wrapped electrical tape over them. Moisture and time did the rest. When I grabbed them to see if they were tight, they fell apart in my fingers.
I spliced new wires and the engine started within 2 seconds and ran. I hadn't started this car in 4 years and it was scary how fast it started. Within 5 minutes it was warmed up and running pretty smooth.
Thanks for all the help, it was just a simple problem.
mrbaddog is offline
post #5 of 7 (permalink) Old 04-07-2008, 10:05 PM
Glad...
to hear it turned out to be a simple problem. Heat-shrink tubing also works wonders on some of these wiring issues...
JR
post #6 of 7 (permalink) Old 04-08-2008, 02:53 AM
Eirik 400 SE's Avatar
Date registered: Jan 2008
Vehicle: 1973 W115 200 /8
I know, it's just so lovely when you barely touch the key and then the car purrr's like a kitten..
The /8 200 1971 I've just bought are the same..
1991 W140 400 SE - SOLD !!
1973 W115 200 -For sale as project.
Eirik 400 SE is offline
post #7 of 7 (permalink) Old 04-08-2008, 07:19 AM
Eirik 400 SE:
Are there many of the /8 cars left in Europe these days? I would suspect with the TUV, or its equivalent, and the heavy use these got as commercial vehicles [taxis and the like] most would be long gone from the roads.
Here in California you still see them in the road with a fair amount of frequency. I kept my 250/8 from 1979 until the year 2000 or so; it was a great car.
JR
1972 280 sel M130 no start condition demon5spd Vintage Mercedes-Benz 9 03-29-2008 01:13 PM
1971 280 Sel 2.8l Osborne Vintage Mercedes-Benz 7 12-12-2006 03:18 PM
FS: 1971 280 SE Sedan Shab For Sale/Wanted/Trade/Giveaway 1 11-14-2006 04:44 PM
Hear a 'click click click' - all dash lights come on, but she doesn't turn start or even crank . roadsession W163 M-Class 11 09-08-2004 02:13 PM
For Sale 1971 280 SL Guest (MBNZ) General Mercedes-Benz 1 04-14-2001 12:44 PM
