» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > Vintage Mercedes-Benz
Old 03-12-2008, 08:02 PM   #1 (permalink)
Date registered: Mar 2008
Vehicle: 1979 300sd turbo diesel
Post 79 300sd no oil pressure
Hey all. I'm new to Mercedes and I have a 1979 300sd. I bought it with 195000 miles on it and it has run great until today. It is almost time for an oil change and I drive long distances regularly, so I checked my oil as usual. Saw it was low and added appropriate amount to bring to the proper level. Upon restarting my car I heard a loud engine knocking, posible lifter? I started to drive the car and pressure went from 45 to 0 and I lost most of my power. The car barely made it onto the car trailer. Any ideas? Any and all help is appreciated.
diesel79 is offline   Reply With Quote
Old 03-12-2008, 08:36 PM   #2 (permalink)
E=MBČ
GermanStar's Avatar
Vehicle: GermanStar.net
The most likely culprit is an oil pump or oil pump chain failure.
German Star
GermanStar is offline   Reply With Quote
Old 03-13-2008, 04:55 PM   #3 (permalink)
will that also account for the tapping? or is that a lifter?
Old 03-13-2008, 04:59 PM   #4 (permalink)
79Mercy's Avatar
Date registered: Oct 2006
Vehicle: 1979 280CE
The tapping was the loss of oil pressure.
'79 280CE with 210,000 miles and still going strong!!
79Mercy is offline   Reply With Quote
Old 03-13-2008, 05:26 PM   #5 (permalink)
E=MBČ
GermanStar's Avatar
That was the sound of your valve train sans oil.
Old 03-25-2008, 03:34 PM   #6 (permalink)
Looks like bad news for my Benz. Oil pump and chain are ok. Bad news is metal shavings in my oil pan. I guess I should start tearing apart the motor. I think it spun a bearing but not entirely sure.
Old 03-25-2008, 10:55 PM   #7 (permalink)
Vehicle: 75 450SLC W107
Excuding bad oil pressure sensor, sounds like you wiped a main bearing but more likely check the oil filter to make sure the oil pressure bypass is not stuck open. ie. try changing the oil filter before pulling the motor.
JJSMILHOUS is offline   Reply With Quote
no oil pressure. could the oil pump be the only problem? chimpum-callao W124 E,CE,D,TD Class 2 12-04-2007 09:10 PM
Oil pressure gauge showing no pressure justin2 W140 S-Class 1 11-06-2006 09:38 PM
85 300sd oil pressure geord h W126 S,SE,SEC,SEL,SD,SDL Class 5 06-16-2006 05:19 PM
300SD oil pressure 1982_300SD W126 S,SE,SEC,SEL,SD,SDL Class 5 02-16-2005 12:33 AM
HELP! Oil Pressure Question...Loss of Power? 82' 300SD fortinfam W126 S,SE,SEC,SEL,SD,SDL Class 4 11-01-2003 05:26 AM
