Idle havoc and brake issues! Help! 3.5 V8(M116.980) - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 02-27-2008, 01:07 AM Thread Starter
triskaideka's Avatar
Date registered: Jul 2005
Vehicle: '68 280SE (w108), '72 280SE 3.5(w108), '88 560SEL(w126), '97 E50 (W210
Quoted: 4 Post(s)
Send a message via Yahoo to triskaideka
Hi all! Haven't driven my 3.5 for the past 3 weeks. When I started her yesterday there was a loud pop right in the air cleaner, and smoke came out of the air cleaner mouth. Guess she backfired right through the throttle body. Started her again after I removed the air cleaner and checked for loose connections, and although there wasn't any loud pops, it was replaced by a series of intermittent little pops. And the idle was seesawing nonstop. I tried removing the spark plug cables one by one to see which cylinder was doing this, and I could only verify that 6 of them were not the source (I think, since I could still hear the popping). I couldn't reach/pull out cables for the number 4 and 8 cylinders, it was dark and hard to access. I'll try again. Before the backfire issue came the idle would seesaw a bit, but she would settle down after a few minutes (I assume when the engine has warmed up a bit).
Started the car again today and the same thing. Seesawing idle, mini pops in the engine. I'm hoping to get some time off with the weekend coming up so I can resolve this issue. What seems to be the problem? Rich mixture? Sitcking valves? Has anyone experienced this? Your advice is greatly needed and appreciated.
And one more thing, when I put the car into gear it takes a lot of brake pedal effort (floored and stomped on hard) to keep her from going, especially in R. But if I shift her into N while she's creeping the brakes bite right away. Would this be related to my problem above? Or would this be a separate issue? Please enlighten me with your inputs. It's frustrating enough not having the time to drive the car, it even worse when the car refuses to cooperate when I have the time to use it.
Thanks everyone!
'68 280SE (w108)
'72 280SE (w108) 3.5
'88 560SEL(w126)
'97 E50 (W210)
triskaideka is offline
    S600 low battery issues (Limp home, Idle issues, P1581 DTC and ESP lamp)... bdkorn W140 S-Class 8 04-07-2008 09:24 PM
    idle issues rzsquared W123 E,CE,D,CD,TD,TE Class 8 10-06-2007 11:45 AM
    Let's have another go at idle issues! CowtownBallin W124 E,CE,D,TD Class 11 02-26-2007 05:47 AM
    idle issues mobeyone W203 C32 AMG, C55 AMG 0 10-09-2005 05:00 AM
    Electrical gremlins causing havoc with my brake lights Tom Deckowski G-Class 7 05-25-2004 02:10 PM
