» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > Vintage Mercedes-Benz
Old 02-22-2008, 04:01 PM   #1 (permalink)
Date registered: Feb 2008
Red face 230 Sedan Fuel Delivery
Hi All -- this is my first post. I'm glad to be a member!
I've got a 75 230 sedan (W115). On occasion, usually when it's wet out (not unusual here in Seattle), I get a momentary -- like a second or even half a second -- loss of power, and then it kicks back in. I don't think it's the fuel pump, so I'm thinking of carb problem. I'm also getting miserable gas mileage -- I know I shouldn't expect too much from a 93 hp gas engine powering a 3500+ lb vehicle -- but we're talking almost V-8 levels of consumption: 12 mpg on average, maybe 15 if I'm doing a lot of highway. So perhaps I need some carb work?
In my quest to improve performance and and economy, I have some questions:
1. Does Weber make a conversion for this car?
2. Would any increases in performance and economy be worth the expense?
3. Does anyone know if it's possible to convert to fuel injection?
the car is a beauty -- I bought it a few months ago with 60k original miles (documented), for a really good price, and drive it every day. I love it -- so I don't mind spending a bit. Any opinions/advice/recommendations? Thanks!
GetBenz is offline   Reply With Quote
Old 02-23-2008, 08:04 AM   #2 (permalink)
flyboyike's Avatar
Date registered: May 2003
Vehicle: '79 280E
Hello and welcome!
Let's start with the easy stuff: when was the last tuneup? What you're describing can be attributed to any number of things (bad spark plug wire(s), cracked/corroded distributor cap, dirty valves etc etc).
flyboyike is offline   Reply With Quote
Old 02-26-2008, 10:16 AM   #3 (permalink)
Re: 230 Sedan Fuel Delivery
Your suggestions all make sense and are well taken. Regarding the tune-up, I have to check the previous owner's records, as I've barely driven the car 3k miles (just did my first oil change last week). Regardless, I wouldn't mind making some performance/economy/drivability enhancements at some point.
Thanks!
Jeff
Old 02-26-2008, 05:09 PM   #4 (permalink)
flyboyike's Avatar
Vehicle: '79 280E
Thanks!
Jeff
Which is why it's adviseable to do a complete tuneup together with a fuel system service (new fuel filter, carb cleaning etc). I would submit to you that you will see a noticeable improvement.
Old 02-26-2008, 05:17 PM   #5 (permalink)
E=MBČ
GermanStar's Avatar
Vehicle: GermanStar.net
I concur wholeheartedly with flyboy, do a complete tune-up so you'll have a performance base to work from and eliminate some obvious potential culprits. In general, the original carburetor on your car has a fine reputation, unlike some other Benz carbs...
German Star
GermanStar is offline   Reply With Quote
Old 03-04-2008, 09:19 AM   #6 (permalink)
Thanks!
Very helpful. Stay tuned for an update...
Old 03-04-2008, 03:00 PM   #7 (permalink)
E-Class Owner's Avatar
Vehicle: 1997 Mercedes Benz E420
Older Mercedes are not known...
for their fuel efficiency. I owned a W114, 250/8 for about 20 years. The mileage on the highway was typically 20, but around town it was more like 12-13, and mixed driving was 15-16.
You have a pretty heavy car for a car with a relatively small displacement "mill"; the engine works hard, and being carburetted with a fair number of emission control devices does not help...
Good luck,
JR
E-Class Owner is offline   Reply With Quote
Old 04-28-2008, 03:35 PM   #8 (permalink)
Thanks. I posted a more recent query -- didn't think these were archived so far back.
W108 Fuel Delivery Problems - No Power to Fuel Pump 1972 280 SE 4.5L Vintage Mercedes-Benz 0 01-08-2007 01:11 PM
1967 230 SL Fuel delivery problems Marco Polo Vintage Mercedes-Benz 4 12-13-2005 07:46 PM
04 C 230 K Sedan for $30,700?!? keoni1978 W203 C-Class 5 06-02-2004 08:13 AM
05 230 Sport Sedan Muzzler200 W203 C-Class 0 05-20-2004 04:48 PM
SLK 230 Delivery Checklist Paul R170 SLK Class 3 08-10-2001 10:27 AM
