» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > Vintage Mercedes-Benz
Old 02-05-2008, 08:52 PM   #1 (permalink)
Date registered: Feb 2008
Post Need help figuring out what engine this is.
Facts I know about the engine came from a 2 seater, its an I6 only visible thing that I could discern to attempt to ID the engine is the number[180 223 38 04 230/250(?)] in the last photo. After attempting to look through countless images threads and various MercBenz sites and tables.
I'm leaning toward the fact that it could be from a W107 Chassis.
Some help would be much appreciated.
hammerzeit is offline   Reply With Quote
Old 02-06-2008, 05:38 AM   #2 (permalink)
B-McD's Avatar
Date registered: Aug 2005
Vehicle: '79 450 SLC
Send a message via MSN to B-McD
280? The actual engine number should be on the block somewhere though.
B-McD is offline   Reply With Quote
Old 02-06-2008, 06:24 AM   #3 (permalink)
Looks like a 230 or 250 judging by the engine mounts and exhaust. My guess is pre W108.
Dirty108 is offline   Reply With Quote
Old 02-06-2008, 07:04 AM   #4 (permalink)
E=MB˛
GermanStar's Avatar
Vehicle: GermanStar.net
^ Yup. Most likely a 114, 130 or 180 engine. There should be a plate toward the top of the block that reveals the engine number.
German Star
GermanStar is offline   Reply With Quote
Old 02-06-2008, 08:32 AM   #5 (permalink)
Date registered: Dec 2003
Vehicle: 1989 300SE, 1989 420SEL, 1965 220S, 2002 Ford Crown Vic Police Interceptor
On the block above the oil filter mount is a flat spot and the engine serial number is stamped there. Use some fine sandpaper to clean the flat area and some chalk to make the numbers visible. They will be in for form NNN.NNN-1N-NNNNNN. Most likely it's from a W108 280S, by the look of it.
The engine is a M180 so the s# will be 180nnn-12-nnnnnn. The 12 signifies a left hand drive automatic transmission engine.
For instance:
Near Manassas Va. '89 300SE, 2002 Ford Crown Victoria Police Interceptor, 89 420SEL
Had '65 220SE, 67 230S, 72 280SE 4.5 Dad had '65 300SE LWB, '65 220SE
"Of all tyrannies, a tyranny sincerely exercised for the good of its victims may be the most oppressive." C.S. Lewis
wbain is offline   Reply With Quote
Old 02-17-2008, 06:31 AM   #6 (permalink)
halman2228's Avatar
Date registered: Jul 2004
Vehicle: 84 500Sl (Euro)
Manifold gives a hint...?
Wouldn't that number on the exhaust maniforld (?) tell us...
180-223-38-04 230/250, the 180 (engine #) and perhaps the 230/250 means it is interchangeable between the 2.3 & 2.5?
Regards,
Kevin
"Dangerous with a wrench and not smart enough to know it"
1984 Euro 500SL, 1984 280SEL (Euro)
1977 280SE, 1990 560SEL
1978 450SEL 6.9, 1979 450SEL 6.9
1979 300SD Turbo, 1988 300CE
1981 280SL, 1967 230SL
DDs: 2004 F150 Crew 2004 Chry Pacifica (wife's)
halman2228 is offline   Reply With Quote
Old 02-17-2008, 10:50 PM   #7 (permalink)
He needs to look at the engine number stamped on the block.
Old 02-20-2008, 03:54 PM   #8 (permalink)
Thumbs up
Thanks wbain, I found it. Unfortunately I forgot the piece of paper with the # on it :\
For instance:
New Help Figuring out What Wires to Connect.... mbnz230 Audio & Telematics Forum 4 07-26-2007 12:17 PM
need help figuring out how to lock/unlock my 300TD Wagon garybeck W123 E,CE,D,CD,TD,TE Class 3 10-31-2005 05:01 PM
Need help figuring out color code for engine harness at cam shaft connection, could someone please c johan6504 W124 E,CE,D,TD Class 1 05-18-2004 04:59 PM
wierd engine behavior w/ check engine light, dealer unable to solve spovilaitis R170 SLK Class 6 12-12-2003 08:05 PM
Say you have a 2.3 engine or a 3.2 engine. Is that called engine size ? engine capacity ? Vince R170 SLK Class 4 11-01-2001 08:14 PM
